fuel problems
Old Jun 9, 2022 | 02:29 PM
basdog's Avatar
basdog
Pin 6 to ground makes the relay click, but no pumps running, key on
i guess i know where fuel pump relay is now
Old Jun 9, 2022 | 02:44 PM
rla2005's Avatar
rla2005
Check the inertia switch.
Inertia Switch Location
firewall forward of the e-brake & clutch pedals
Fuel system diagram (gas engine)
Old Jun 9, 2022 | 03:29 PM
basdog's Avatar
basdog
ITS RUNNING!!
I check Inerta the other day it was in the down position.
I rechecked today still in down position so i pushed it up and grounded pin 6 still clicking at relay.
pushed inerta back down 6 pin to ground and fuel pressure gage at rail jumped to 40 psi and truck started right up. Reset?
Couldn't have done it without you all.
Thanks so much
I have this odd feeling i didn't have to spend any money at all. Ouch
Old Jun 15, 2022 | 01:51 PM
Marcus_'s Avatar
Marcus_
3rd Gear
I have a 93 f150 with crank and start but runs and idels poorly. The icm pressure regulator and fule pump are brand new. I tried reading codes but have not gotten any. Fule pump runs constantly. Any ideas on where to start looking for a solution
Old Jun 15, 2022 | 03:58 PM
rla2005's Avatar
rla2005
Glad to see you got it resolved.
Old Jun 15, 2022 | 04:00 PM
rla2005's Avatar
rla2005
You should start your own thread for your issue.
The constant running fuel pump and lack of getting codes point to a bad computer. Dozens of threads here with the exact symptoms as you are having.
Old Jun 15, 2022 | 04:10 PM
Marcus_'s Avatar
Marcus_
3rd Gear
Thanks for the input ill start a new thread.
Boofracinginc
Jun 17, 2016 03:39 PM
F Truck08
Aug 29, 2011 04:33 AM
91chevywt
Mar 4, 2011 04:48 PM
mando jake
13
May 11, 2009 06:47 AM
vee-eight-fords
Jun 7, 2004 09:22 PM
