Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Can't find axle or trans code!
Old May 23, 2022 | 09:59 PM
dmignon's Avatar
dmignon
2nd Gear
Hey everyone, thanks for having me on the forum. Lots of really good info here...except a specific trans and axle code! Looking for a decode on this truck
Thanks everyone
Old May 24, 2022 | 12:09 AM
85e150's Avatar
85e150
SL = Spicer model CM5852A five speed transmission. (not indicated if direct or OD)
P4M
P4 = P4 isn't shown for model year 1985, but it is shown as:
'80/'83 = Dana (Spicer) model M185T two speed, 18,500 lbs capacity, 7.17/9.77 ratios
'84 = Dana (Spicer) model M190T two speed, 19,000 lbs capacity, 7.17/9.77 ratios.
The axle may have identifying plates or stamped numbers on the carrier housing and the main axle housing.
M = Ford 7,000 lb capacity front axle with power steering.
Hope that helps.
I do an edit with a full decode if you want, but it will be tomorrow......
Old May 24, 2022 | 12:31 AM
dmignon's Avatar
dmignon
2nd Gear
Fantastic, thank you very much.
whisler
Oct 3, 2013 10:37 PM
boggerted
Apr 7, 2009 12:15 PM
green52
Jan 2, 2005 12:46 AM
RUFUS79
Dec 3, 2003 10:47 PM
