I have 2 pairs of plugs in my tail light wiring harness. 1 pair I believe are the license plate lamps. What is the other pair for ?????? Both look to be stock wiring. The license wiring are brown wires. The other pair feeds off the plug to the drivers side tail light harness, 2 long female connectors...........
I am working on the same harness of my 71 F250 CS..The harness is all hacked from years of splicing and rewiring..
You have two plugs..1 has 2 wires to it and the other has 3 wires to it. One plug has a green wire-Right side turn and brake- The other plug has a yellow wire-Left side turn and brake.
The plug that has the 3 wires to it, the third is the backup lights..
There are 2 female plugs at the midpoint of the harness, with about a foot of space between them..license plate light power..there is suppose to be a light on each side of the plate,,Those 2 female plugs are for the 2 lights.
Your license plate lights are the same wires used for the clearance lights in your taillight housing. Put power to them and see what lights up.
I was thinking of seeing what has power but got sidetracked with life & other little details hat continue to arise as I am finalizing the LAST FEW ha,lol details that never seem 2 go as planned..........
What r clearence lights ? Also I appear 2 have an extra set of female connectors. I took photos & may post them soon.........I am intensely focused on completing these last details because I am SOOOOOOOO VERRRRRRRYYYYYYY close to DRIVING my much loved TRUCK...........it has been sitting WAYYYYY 2 LONGGGGGGGGG.
So very close........thank-you both sooooooo verryyyyyy muchhhhhhhhhhh
Sincere thank-yous to u both.......apologize 4 the delayed response..........I have been swamped with work and etc.........etc.......etc.......
The clearance lights are all of the dimmer lights that come on when you pull the switch halfway out. tailights, license plate lights, the lights on the side of the truck and the dimmer lights in your turn signals. If i remember right Ford has them wired on a brown wire like trailers.
Well Tumbleweed all my lights are working ok all but back-up lights...which I will attempt to install bracket & switch and hopefully turn them on too......
I seem 2 have an added set of factory connectors to what I do not know.........I will post a pic later to show all.........they are not the license plugs 4 I have found them...
Thank-you so very much 4 your kind help..........I am not getting the as many responses as I normally do........ so u r very appreciated......Thank-U...
