Pitman Arm Troubles
Old May 21, 2022 | 03:58 PM
CClark1172's Avatar
CClark1172
1st Gear
Pitman Arm Troubles
So I have a 89 f150 that has a 79 f150s solid axle up front (last owner swapped it from the Twin I Beam to a solid). The new tie rods stud won't fit through the pit man arm because the channel is too small. The top of the tie rod stud is 5/8" and the bottom is 11/16". What size reamer should I get?
