Need Help!
Old May 19, 2022 | 11:33 PM
Brandon_McCoy93's Avatar
Brandon_McCoy93
1st Gear
Lightbulb Need Help!
I have a 2003 F-250 with a 7.3 in it, 4WD with an 8-inch lift already on it. I bought it this way, and I want to lower it, because it rides like crap, and it is just a pain to take anywhere. For now, I was thinking about just going with a leveling kit, and calling it good. I would love to see some pictures of people who have done this, and opinions on what is the best kit to do this with, as far as riding the best, (as possible), quality lift, and sitting level with the back. Also, I would like to know what size tires and wheels with the offsets ya'll are running, because, if possible, I would love to go as big as I can without them rubbing the front springs, because it has 37's on it now, and it rubs quite a bit, and I need a football field to turn it in right now. I know I have to buy all new springs, so any help would be appreciated. Thank you!
Old May 19, 2022 | 11:49 PM
b00stleak's Avatar
b00stleak
I did something very similar. I picked mine up with a 6" and 37s. Dropped to a 4 and "35"s. You will most likely need shorter shocks, rear blocks and u bolts, front springs and u bolts. That's basically a whole kit. What I did was buy a kit and then left the pitman arm and trackbar bracket on the truck. Sold everything else as a complete kit to someone else. You can read my thread if you want. Maybe it can help you out. I'm about to change my springs out again for a softer riding pro comp spring.
https://www.ford-trucks.com/forums/1...ld-thread.html
Old May 19, 2022 | 11:51 PM
udsuth78's Avatar
udsuth78
It's rubbing 37's with 8" of lift? 37 what on what wheels? I cleared 285/75R16 mud treads on stock wheels in the oilfield and the only time I ever rubbed a tire was when a leaf spring broke. That was on front leveling springs with OG rears until they broke. Pretty sure some guys are clearing 315's with similar setups.
Old May 20, 2022 | 12:26 AM
b00stleak's Avatar
b00stleak
Hes probably got wider than stock wheels and the same offset. Combine that with the taller and wider tire and you get tire rub for days.
fordfirechief
Feb 20, 2015 07:48 PM
AZGUY
Nov 17, 2009 07:05 PM
bigsteve1969
May 19, 2009 12:36 AM
RyanMackD55
Mar 13, 2007 03:28 PM
TOMPANDS
Nov 6, 2005 07:18 PM
