Running Board step plates
Old May 19, 2022 | 03:05 PM
Vegastype's Avatar
Vegastype
I purchased the ford script step plates for my running boards and cannot get the inner and outer mounting holes to land on ridges. It is either the inner or the outer can be on a ridge but not both. Has anybody else run into this problem? My running boards are not original and came from Midwest Early Ford.
Mike
Old May 19, 2022 | 06:56 PM
abe's Avatar
abe
I have no experience with those blasted things, but you could put a spacer under one end
Old May 22, 2022 | 07:43 AM
avf100's Avatar
avf100
I didn't put these on my truck ( I didn't want to upset Abe )
But every picture I've seen, the outer holes are lined up with the running board rib and the inner holes are not. So I'm assuming that some sort of spacer was used.
Old May 22, 2022 | 08:37 AM
jniolon's Avatar
jniolon
old and in the way
I've got flat glass running boards so I had no decision to make... but this is how I've seen them
Old May 22, 2022 | 08:42 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I had the same problem. Dennis Carpenter reproduction running boards from original Ford toollng. Dennis Carpenter told me the tooling was worn our and the ridges were at different heights. I used a few small plastic washers to level the step plates onto the uneven ridges of the running boards.
Old May 22, 2022 | 09:29 AM
hooler1's Avatar
hooler1
I had the same problem too. But on mine which are OE running boards, (step plates from Mid-Fifty) the top holes did not land on top of a rib so I used stainless nuts as spacers. A guy could make his own spacers out of a piece of 1/4" air brake hose, 3/16" brake line with a rubber washer, or a smaller piece of rubber hose from a radiator over flow, a piece of vacuum hose etc..
Old May 24, 2022 | 03:15 PM
48 Steel's Avatar
48 Steel
Tlta29
Jan 9, 2022 12:13 PM
F100supercrew
Jul 6, 2021 09:31 PM
Corner Gas
Apr 7, 2010 08:37 PM
