Sponsored by: Real Truck
Radio interchangeable? 2015 SD
Old May 19, 2022 | 01:29 AM
SUPER MALO's Avatar
SUPER MALO
Would it be a direct replacement of my stock CD player with the radio below?
https://www.ebay.com/itm/2006-Ford-Explorer-AM-FM-6-Disc-CD-Player-Navigation-Radio-Receiver-OEM-/313983040209?mkcid=16&mkevt=1&_trksid=p2349624.m46 890.l49286&mkrid=711-127632-2357-0
Thanks,
MALO
Old May 19, 2022 | 07:32 PM
leadmic's Avatar
leadmic
Not for a 2015..
Old May 20, 2022 | 07:00 AM
SUPER MALO's Avatar
SUPER MALO
Originally Posted by leadmic
Not for a 2015..
Can you please explain, the plugs in the back are the same.
Thanks,
MALO
Old May 20, 2022 | 07:46 AM
JKru's Avatar
JKru
I'm in the "if it fits & the plugs match, then what could possibly go wrong?!" camp, but for the same or just marginally more money, you could get a brand new unit that is guaranteed to work. Check out Crutchfield.
https://www.crutchfield.com/g_168550...Receivers.html
Old May 20, 2022 | 01:42 PM
leadmic's Avatar
leadmic
Thanks,
MALO
The ad clearly says it's for 2006. Why did you buy it? In 2013 Ford went to Sync2 and got rid of the brick. The brick is the radio you posted. Will it work, I don't know. If you plug it in and you let the smoke out it will be money wasted. It's your truck and your money, but if it were me I would get a known compatible radio.
Old May 20, 2022 | 04:34 PM
SUPER MALO's Avatar
SUPER MALO
I didn't buy anything yet, I was just asking if one as this would work ???
Old May 21, 2022 | 01:25 PM
leadmic's Avatar
leadmic
Sorry about that I misunderstood your post. Is your radio the standard non-NAV radio?
Old May 21, 2022 | 04:46 PM
SUPER MALO's Avatar
SUPER MALO
Yes, it is. 👍
Old May 22, 2022 | 07:01 PM
leadmic's Avatar
leadmic
I would go with a aftermarket. It will be cheaper and have more features than retrofitting a factory NAV radio.
Old May 25, 2022 | 10:23 AM
acdii's Avatar
acdii
You will need a sync adapter for aftermarket installation, and pre sync factory radios won't work with the stock sync either. If it is a double DIN opening, there are quite a few replacements that are decent radios. I installed a Kenwood with Garmin nav in my 2012, and uses a Maestro Sync/steering wheel adapter to tie the controls in with the radio.
These are everything needed to add radio, Sync, Nav and Sirius XM.
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
H1449-6
Sep 18, 2013 09:44 AM
palm trees for me
2004 - 2008 F150
Nov 11, 2008 08:51 PM
97F260LD
1997 - 2003 F150
Jan 17, 2005 03:49 PM
