So I have a 1984 F350 that I've done a TON of service on, including new parking brake cables on the rear, and a new equalizer. The only issue: I dont know how to properly adjust the cables to have good park brake engagement. This is a manual truck, so good park brakes are important.
does anyone on here know how to adjust the cables?
On mine I took up on the play so when I step on the pedal it clicks 2 or 3 times and dose not go to the floor.
Been holding pretty good but i also leve it in granny gear.
Dave ----
Make sure to manually adjust the rear brake shoes before doing anything with the cables.
Here’s a good video explaining the process. The subject vehicle is a Jeep, but the general principle is the same. The video starts with the drums removed for a better view, but around 3:00 he shows how to adjust the shoes with no need for any disassembly. Remove the rubber plug for access, and that’s it. The process is actually very quick:
This is something I haven't addressed yet with my 82, I learned young never to use the park brake on an F-150 unless I had a hammer and a pair of vise grips in the truck. So this is an interesting discussion.
I learned young never to use the park brake in the winter as the cables can freeze and not release.
Or the shoes to the drums.
Dave ----
Yeah my oldest memory of this issue is being in my high school parking lot with a set of vise grips and a hammer in -25C weather trying to unstick it so I could go home after playing Warcraft 2 against the mechanics teacher.
