Swapping rear diff
Old May 16, 2022 | 08:24 AM
Tobias Westberg's Avatar
Tobias Westberg
2nd Gear
Swapping rear diff
Hello from Sweden!
I have sterling 10.25 axle code C5.
It’s a 4.10 with lsd.
In my other truck i have axle code 39.
It’s a 3.55 without lsd.
Is it possible to change the hub and gearing?
I want 3.55 with lsd.
Last edited by Tobias Westberg; May 16, 2022 at 08:32 AM. Reason: Changed one line
Old May 16, 2022 | 08:41 AM
jas88's Avatar
jas88
Yes, you can swap the ring and pinion gear but you would then need to set up the pinion depth and side clearance.
Old May 16, 2022 | 09:35 AM
Tobias Westberg
2nd Gear
That is great news!
I Will look at some youtube clips how to do the adjustment then.
Old May 16, 2022 | 09:36 AM
Robfinger's Avatar
Robfinger
The 10.25 is very much like an 8.8 in that 9 times out of 10 if you reuse the shims that your axle came with in the exact positions they were in from the factory the new gear mesh pattern comes out perfect as long as the both old and new gears are factory Ford sets and not something aftermarket. At least that's been my experience with these axles.
Old May 16, 2022 | 10:03 AM
PhilHill's Avatar
PhilHill
My mantra has always been DIY on all my projects, assuming I am comfortable with the task. Several years ago, I attempted to set up a new ring and pinion and after purchasing the tools, and removing the diff from the vehicle several times (labor intensive), I decided it was time to concede and let a professional do it. I’ve not given up though, if I find myself in a similar situation with my 54, I will of course try the DIY approach again. I thin my biggest mistake is that I should have taken more photos and pay close attention to shim location during disassembly. Good luck and have fun.
R/Phil
scottw1
Sep 12, 2013 10:00 AM
Baja16
17
May 16, 2013 11:59 PM
kjjr20
2009 - 2014 F150
Oct 21, 2012 04:05 PM
bozzzz94
Aerostar
Mar 7, 2007 08:23 AM
1cool60
Nov 8, 2003 12:02 PM
