Distributor alignment direction
Old May 16, 2022 | 06:59 AM
nighthawking's Avatar
nighthawking
Distributor was taken out without referencing anything. Does it matter which way the vacuum advance diaphragm points on a 1977 391 Ford engine in a F750 crane truck? Not sure if picture has correct alignment. PO said truck backfired. What is a good/easy replacement distributor/conversion for the stock points dizzy?
Old May 16, 2022 | 08:25 AM
'65Ford's Avatar
'65Ford
I don't think position of vacuum diaphragm matters on any vehicle. Just put that where it's convenient. Aiming the rotor at the correct contact inside the cap is what matters. If you didn't check that alignment before removing the distributor then you'll have to reset. I like to bring #1 piston to top dead center on the compression stroke and aim the distributor rotor to the correct contact on the distributor cap (the contact that's connected to the plug running to #1 cylinder). Then verify the plug wires are connected based on the firing order.
Old May 16, 2022 | 01:04 PM
f5fordgirl's Avatar
f5fordgirl
The wires look to be in the right order in the cap, if they go to the right plugs, and TDC is compression stroke, it shouldn't back fire.
Old May 17, 2022 | 11:22 PM
351Cleveland C4's Avatar
351Cleveland C4
I feel there may be a severe lack of understanding on how a distributor works in this thread.....
I can't explain it without going into a whole bunch of engine operations.....
Old May 18, 2022 | 10:28 AM
kenny nunez's Avatar
kenny nunez
Distributor
While I am not crazy about the way the vacuum advance is pointing, if it runs that way, leave it as it is. The best thing to do would be a Petronics electronic conversion to eliminate the points and condenser. That would make it easier o start as being a crane truck I bet it sits for long periods between jobs.
Old May 18, 2022 | 11:50 AM
'65Ford's Avatar
'65Ford
For someone who is usually helpful, I don't understand your rather cryptic comment. I'll say I don't see how f5fordgirl can see if the wires are connected to the dizzy correctly without seeing which plug they're connected. That, and based on the picture, no one can see where the rotor is pointing.
Old May 18, 2022 | 12:30 PM
f5fordgirl's Avatar
f5fordgirl
The plug wires are marked, they are in the right rotation and order, 1 5 4 2 6 3 7 8, and I said, if they are on the right plugs, and timed at tdc compression it should go, but you are right, if the rotor is at #1.
Old May 18, 2022 | 01:13 PM
'65Ford's Avatar
'65Ford
Okay, I see what you mean by numbers. I didn't notice those before. Not sure but looks like the number 7 on the coil wire which seems weird. Appears the wires (based on the numbers) at least run to the correct side of the engine.
Old May 18, 2022 | 09:51 PM
DirtyFerd's Avatar
DirtyFerd
It doesn't really matter where the vacuum canister points but the problem you'll run into is that if it's not correct, you'll have to adjust your distributor and the plug wires won't be long enough. Older vehicles this is no problem, you just move your plug wires over. On newer vehicles the computer uses the distributor to trigger the injectors so it must go in correctly
rswhitmore
Mar 16, 2022 09:16 AM
chris989
Sep 19, 2021 07:52 PM
TMI
Jul 15, 2016 07:25 AM
Connie Marie
Aug 28, 2003 05:07 PM
dillon1033
Feb 9, 2003 12:52 PM
