84 f150 distributor
Old Aug 27, 2003 | 01:55 PM
Connie Marie's Avatar
Connie Marie
From: Bama Gal transplanted to the Pacific North West
Angry 84 f150 distributor
Okay, i'm back here on the forum...yeah it's been a while but i thought i was through with mechanical and on to body work...ARGHHHH!!!
I am having problems with my distributor, I have replaced the original carb with a two barrel holley, removed emissions equipment (no emissions here) and now i want to replace my distributor with a points distributor, with a vacuum advance.... I need to know what points distributor i can go to, I don't need a "performance ignition"....just somethin' simple...any suggestions???
Old Aug 27, 2003 | 02:27 PM
stangboy_82's Avatar
stangboy_82
84 f150 distributor
why would you want a points distributor?
Old Aug 27, 2003 | 02:42 PM
Connie Marie
84 f150 distributor
first of all, they are simple...never, on any old points truck i've had did i get stuck in the middle of no where without a ignition module to fix the truck
second thing is...i'm ripping everything out of this truck....i just want basics...no modern stuff....all i need is for it to run..lights to work.. etc etc etc...
Yall can keep all that electronic stuff....i prefer my life without it...up here in the cascades, with the closest parts store a 120 mile trip...simpler the better...and points are easier to keep spares in the truck than all that other stuff
Old Aug 27, 2003 | 02:55 PM
fseriespower's Avatar
fseriespower
84 f150 distributor
I wonder if a points distributor off a older 302 would work if it does go to the junkyard. But there is more to go wrong on a points distributor anyway. I would just leave it if it works.
Old Aug 27, 2003 | 03:01 PM
Connie Marie
84 f150 distributor
302 wont work ....different shaft
Old Aug 27, 2003 | 03:02 PM
stangboy_82
84 f150 distributor
well any points distributor from a 351, 302 distributor shaft will be shorter won't work with a 351, I'm assuming you don't have a roller cam for some strange reason. But I still don't know why you would want a points distributor a durasparkII system is much more reliable, it holds up to water better, lasts longer, has a stronger spark, and is just as easy to wire into your truck. there is no advantage to a points distributor at all if you're worried about spare parts you can mount 2 ignition modules on the firewall next to each other and in the rare case that one goes out then you can just swap the wire's don't even have to take the distributor cap off and you're back on your way.
Old Aug 27, 2003 | 03:06 PM
fseriespower
84 f150 distributor
I didnt even think of that thats a pretty good idea. hey stang will u check my post about my radiator?
Old Aug 27, 2003 | 03:13 PM
Connie Marie
84 f150 distributor
it isn't a duraspark 2 btw
Old Aug 27, 2003 | 03:18 PM
Connie Marie
84 f150 distributor
going to go blow this one up and go fix my older truck's frame...no electronics, ahhhhhhhhh
Old Aug 27, 2003 | 04:33 PM
GypsyR's Avatar
GypsyR
84 f150 distributor
Well, if you're bound and determined to go with points just pick up a distributor and coil for a 69-73 Mustang/Torino/Ranchero (off the top of my head). Be sure to use a ballast resistor as a points coil uses less than 12 volts while running (12 volts when starting). If you run 12 volts all the time, it will work until you burn up the coil, condenser, or points. Usually in that order.
I went through something similar on my old Harley, spending a bunch of money to upgrade it to electronic ignition. After a bunch of screwing around and having problems 600 miles from home, I said screwit and went back to points. Happy ever since.
In contrast to a variety of Fords I've driven and am driving. Most had Duraspark II's or I converted them to it. I keep a spare Duraspark box around (currently own 3 Mustangs, 2 F150's, and a Bronco) but in 20 years, I've yet to ever need it. Or in fact ever have any Duraspark related problem. Ford did good.
Now if only they made a Duraspark for Harleys....
Old Aug 28, 2003 | 12:20 PM
Connie Marie
84 f150 distributor
GypsyR, This truck doesn't even have the right wiring for a duraspark two...seems funny to me, but looks like oe wiring...
and as for the harley....there's a few good ignitions out there, but i'm a magneto fan there ....laughing...been told that magneto's are obsolete, then i see all the racers using them still...it's one of those things...ya got it all set right and keep an eye on it from time to time...it'll never fail ya...
k i'm gonna go try to find a distributor today.....so far three wouldn't work cause they had short shafts...and they were all spose to be for 351w's ....ya ever feel like chokin a parts guy????
Old Aug 28, 2003 | 05:07 PM
bremen242's Avatar
bremen242
84 f150 distributor
get one for an 82 bronco. it has to be from a 300-6 or it won't fix. if you have a EEC-IV, just disconnect the harness from the fenderwell (by the windshielder washer tank) and plug in a duraspark 2 module (trust me, all the plugs are different, you cant screw it up), and then connect the harness u get from an 82 to the distrubutor and then the ignition box (plus you'll have to plug in the temp & oil pressure senders as well).
