Suggested diagnosis
Anyway-will be monitoring oil this week. I also did a scan with a regular scanner and my Autoenginuity scanner
The PCV hose by all appearances has never been changed in 19 years-probably the PCV valve as well (it hadd 100k on it when I bought it and am now at 114k)
I bought the PCV valve and I ordered that hose assembly that has the coolant lines and the line into the plenum. It won't get here of 7-10 days.
On the scan:
It was showing misfires. It was subtle but once I saw the reading, I paid more attention and I could hear it from time to time. My scanners don't show the cylinders directly that misfired but it seemed some reading was a little different on 2 and 8-can't remember what it was.
Short term fuel trim bank one range was : had +12 , +13, +14 a few times over 3 minutes down to maybe a -6
Short term fuel trim bank two range was : had +9,10,11 down to a -6 over 3 minutes
To me, it was bouncing all over the place.
Long term fuel trim finshed at: Bank 1 -0.78 Bank 2 +4.69
MAF volts mostly around 1.1 -1.8 but some jumps to around 3.9 which coincided with acceleration
MAF rate(lb\min) was around 1.04 at idle at topped out at around 25 when I stomped on it
It did detect a vacuum leak in the evap system although my data stream file didn't captue it. I have gotten a number of P0455 codes(a large leak) over a year.
It will not trip a code but every so often but I guess there is a threshold for that. I've used 3 different new gas caps--once in a blue moon that light pops on but very very infrequently.
I'm hoping this all can be attributed to vacuum leaks. I don't know how to check the vapor cannister, purge valve and all that stuff. I don't even know where all the vacuum lines for the EVAP system are which I guess run from the gas tank to the evap cannister to wherever.
Any thoughts, tips or tricks are always appreciated
