Adjusting speedo
Old May 11, 2022 | 03:55 PM
Mwcrf450r's Avatar
Mwcrf450r
5th Gear
Adjusting speedo
I've searched all over and can't seem to find anything for the bullnose. I'm gonna be putting 35's on my truck after I lift it but was wondering how to adjust the speedo if possible.
Old May 11, 2022 | 04:03 PM
Franklin2's Avatar
Franklin2
You will have to pull the gear out of the transmission or transfer case and see how many teeth are on it. Then put a gear with less teeth on it. You just pull the cable out of the tranny or transfer case, the gear is on the end.
Old May 11, 2022 | 04:26 PM
FuzzFace2's Avatar
FuzzFace2
You may want to wait on the speedo gear change till you change out the front & rear gear set for something like 4.56
Dave ----
Old May 11, 2022 | 07:42 PM
351Cleveland C4's Avatar
351Cleveland C4
To make big changes, a ratio adapter box will be required.
I need to get one after swapping from 3.55 to 4.56. Speedometer needs to be slowed down 17% and that's too much for a simple gear change.
Old May 11, 2022 | 08:17 PM
kr98664's Avatar
kr98664
Oh, it's possible, but in my experience, I was a lot more comfortable after switching to a swimsuit with a more generous cut. No matter how I'd adjust my Speedo, it was always too tight in front and kept climbing in back.
Welcome to the forum, by the way.
Old May 12, 2022 | 06:57 AM
Mwcrf450r's Avatar
Mwcrf450r
5th Gear
awesome thanks!
Old May 12, 2022 | 06:59 AM
Mwcrf450r's Avatar
Mwcrf450r
5th Gear
Thanks wise guy glad to be here. Been creeping for a long time finding info
bradphx
Sep 25, 2016 02:37 PM
Aussie BrianB
Australia Chapter
41
Jul 27, 2013 09:53 PM
Aquik72
Jun 7, 2010 09:25 AM
