03 navigator cluster lights dim when cold
Old May 11, 2022 | 12:03 PM
fixit5561's Avatar
fixit5561
Hey guys,
like in the description, my 03 Navi cluster lights/leds, are so dim when the Temps outside are cold (below 40 degrees) you can read the speedo, tach, etc. when the trucks inside temp is up above about 55 degrees you can then see the speedo.
​anyone experienced this and how did you fix it?
I'm giving the truck to my daughter to take to college next winter in the Michigan UP so Temps are cold up there.
Old May 13, 2022 | 08:18 AM
CircuitBoardMedics's Avatar
CircuitBoardMedics
Good morning fixit. Sorry to hear that you're having issues with your cluster!
I'd like to confirm two things:
1) The gauges themselves are fine and function normally.
2) The cluster is the only module having backlighting issues -- the rest of the dash is lit up as usual and brightens/dims with the dimmer switch.
If you can confirm the two things listed above, then I recommend sending the cluster in for testing/repair. We have a repair service listed here, which restores backlighting to the odo and gauges.
https://circuitboardmedics.com/1999-...isplay-repair/
Please let me know if you have any more questions.
downrange
Aug 31, 2021 09:32 AM
cdmm151
Mar 24, 2012 08:53 PM
kentuckyredneck
Oct 3, 2010 10:22 PM
dartguy699
Jul 21, 2008 11:04 AM
tap8
1983 - 2012 Ranger & B-Series
Apr 7, 2008 12:50 AM
