Hub cap/trim ring
Old May 9, 2022 | 06:29 PM
dfitch1's Avatar
dfitch1
Hub cap/trim ring
Good evening, I'm trying to locate a hub cap and trim ring for my 79 F-250 Ranger. Most of the searches I've done came up empty.
Mine flew off at some point. I didnt realize that these were 2 piece.
Thanks for any suggestions
Old May 10, 2022 | 08:01 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Those are also sometimes referred to as "beauty rings", that might help widen your search. Look like these? Also a slick and easy way to make a plain stock steel wheel look a bit more fancy.
Not sure it that is a trim ring on there or not but it is sharp looking no matter what.
Old May 10, 2022 | 08:36 AM
dfitch1's Avatar
dfitch1
Thanks for the reply, here are some pictures. If I cant find them, maybe I'll pull all of them off and paint them the factory white. Might look even better.
Old May 10, 2022 | 08:56 AM
440 sixpack's Avatar
440 sixpack
there are a bunch of 16.5 Ford rings on ebay I'm not sure which one you need. just search " F250 beauty ring "
Old May 10, 2022 | 08:59 AM
77&79F250's Avatar
77&79F250
Very nice looking truck, I have never seen the ring AND a hub cap used together, it does look like all one piece. X2 on you are going to have to find a very specific 16.5 ring.
Old May 10, 2022 | 09:25 AM
dlburch's Avatar
dlburch
Info on the trim ring for 16.5 wheels...they are different based on wheel width.
https://www.ford-trucks.com/forums/6...ml#post5259247
15" hubcap should be easy to find...
https://www.ford-trucks.com/forums/1...l#post18283886
Old May 10, 2022 | 10:13 AM
tubesaft's Avatar
tubesaft
Used to use those along with a "baby moon" hub cap on my 55 & 57 Chev's
Old May 10, 2022 | 05:13 PM
dfitch1's Avatar
dfitch1
Rim
This is what i have. inside and outside measurments.
Old May 10, 2022 | 05:15 PM
dfitch1's Avatar
dfitch1
I posted some pictures of what i have. Wheel size that is.
Thanks
Old May 13, 2022 | 09:20 PM
dfitch1's Avatar
dfitch1
Still having a hard time finding this beauty ring. The part numbers listed in a previous post don't match up with a 79 Ford but early to late 80's. Has anyone looked at the pictures I posted with the measurements?
THanks again for any help.
the winemaker
Oct 12, 2017 04:53 PM
ahuggins6
Nov 18, 2012 03:51 PM
DonMckay
May 6, 2007 04:35 PM
