shock upgrade
Old May 7, 2022 | 04:59 PM
thestoicmarcusaurelius's Avatar
Originally Posted by PowerKid
I'm leaning towards leapfrogging both and go with King shocks. Not free but I suspect I'll be happy w that choice.
I don't know that there's a huge difference between a Fox or King if you go with a 2.5" diameter shock for both with similar features. Their prices will be very close also. Tuning / Valving and spring rates that are a good fit for your application are probably more important than a specific brand once you decide what level of performance/features you want your shocks to have.
Old May 7, 2022 | 05:04 PM
RidgwaySD's Avatar
RidgwaySD
I suspect only if you change the springs too, otherwise a set of 2.5's or better are kind of wasted on too stiff rear leaf packs and stiff front coils. So honestly you are going to spend like $6000 compared to $600 but yeah, I bet you will like it.
killjoykarl's Avatar
killjoykarl
All done front pass side was a bear took over 2 hour to get the top nut off as the bottom was stripped and kept spinning the shock. Now need to order the front stabilizer.
Old May 7, 2022 | 05:28 PM
PowerKid's Avatar
PowerKid
I've never seen em at $6,000. But been wrong before. Some folks tell me a King will go longer before requiring a rebuild (vs Fox). I have no hard proof though.
Old May 7, 2022 | 06:11 PM
I agree. There's only so much the shocks can do without changing springs or suspension geometry. But, better shocks are better shocks at the end of the day.
Old May 7, 2022 | 06:14 PM
I think he meant that would be the total cost for upgrading other suspension components, not just swapping the stock shocks out for aftermarket stock-length shocks.
I copied below what would be a pretty typical build for a 4.5" lift. It comes out to around $8k for parts only.
$12k once you add the bumper.
Then the bumper needs to be powder coated and everything needs to be installed.
Then at the low end, $1.5k for wheels and $2k+ for 37" or 38" tires.
It would be more for people that want to use a sway bar either buying after market end links for the stock sway bar or an aftermarket sway bar but I'm going to go without a sway bar on mine.
CJC Built 2017-2022 Ford Super Duty Front BumperWarn VR Evo 12-S Winch / White Baja Designs XL and Squadron Sport (677803 & 557803)
QUANTITY
$3,984.89Starting at $361/mo with [***************]Affirm. Learn more
PMF 2005-2020 Ford F250 F350 Super Duty Adjustable 3-Link Arms
QUANTITY
$1,099.99Starting at $100/mo with [***************]Affirm. Learn more
Carli Ford F250/F350 Super Duty 2017+ 4.5" Lift King Pintop 2.5 Shock Package
QUANTITY
$2,830.00Starting at $256/mo with [***************]Affirm. Learn more
Carli Ford F250/F350 Super Duty 2017+ 4.5" Front Bump Stop Drops
QUANTITY
$180.00Starting at $17/mo with [***************]Affirm. Learn more
Carli Ford F250/F350 Super Duty 2017+ 4.5/5.5" Lift Brake Lines
QUANTITY
$255.00Starting at $24/mo with [***************]Affirm. Learn more
Carli Suspension 17+ Ford True Dual Stabilizer Low Mount/High Mount Kit
QUANTITY
$1,030.00Starting at $94/mo with [***************]Affirm. Learn more
Carli Ford Super Duty 4.5/5.5" Lift Coil Springs
QUANTITY
$400.00Starting at $37/mo with [***************]Affirm. Learn more
Carli Ford Super Duty Reservoir Mounts2.5 inch shocks
QUANTITY
$85.00Starting at $15/mo with [***************]Affirm. Learn more
Carli Ford F250/F350 Super Duty 2017+ Full Progressive Leaf Springs - 4.5" Lift
QUANTITY
$1,670.00Starting at $151/mo with [***************]Affirm. Learn more
Carli Ford Super Duty 2017+ Adjustable Track Bar
QUANTITY
$520.00Starting at $47/mo with [***************]Affirm. Learn more
Old May 7, 2022 | 08:49 PM
knaffie's Avatar
knaffie
King is no better than Fox. The performance depends on how they are valved. They're both good shocks.
Old May 8, 2022 | 07:30 AM
RidgwaySD's Avatar
RidgwaySD
They both need regular rebuilds they are both very good products. As mentioned just doing a set of 2.5s while better doesn't take advantage of the full improvement they can offer when properly paired with the rest of the suspension. When I build my Carli "Backcountry" kit it is $6-7k. That is the only way I would bother stepping inot that high performance of a shock. Otherwise just get Fox 2.0's with resi's and call it a day on your stock suspension. Bilstein also makes a resi shock the 5160 that would be a couple steps above stock. Those are only double the price of a regular set of 5100's or Fox 2.0's Going to 2.5's is a waste of money unless you do all the mods to support them.
Old May 8, 2022 | 07:33 AM
RidgwaySD's Avatar
RidgwaySD
That is when you grab that shock body with a big channel lock pliers and use and impact on the top nut... I would have sawzalled the shaft before fighting it that long. Glad you got them in!
Old May 8, 2022 | 08:23 AM
killjoykarl
I used visecrips I was about to cut it but busted my saws all blade awhile ago and had not replaced lol.
Old May 8, 2022 | 10:16 AM
PowerKid's Avatar
PowerKid
QUANTITY
QUANTITY
QUANTITY
QUANTITY
QUANTITY
QUANTITY
QUANTITY
QUANTITY
QUANTITY
QUANTITY
Ok makes sense. I had bud with f350 w deavers etc rode like a dream. I can't go that high. Stock height w upgraded shocks and ss this time.
Old May 8, 2022 | 10:42 AM
Deaver makes a leveling height replacement spring pack also
Old May 8, 2022 | 11:28 AM
  #28
Leardriver's Avatar
Leardriver
The stock shock was stuck? Do you have a cut off wheel to assassinate the shaft? I look forward to putting Bilsteins on, I hope it isn't too ornery of a job.
Old May 8, 2022 | 09:50 PM
  #29
RidgwaySD's Avatar
RidgwaySD
All four of mine were installed on the ground, no lift, no tire removal, no turning of the wheels in under 45 minutes...
The front stockers like most cheap twin tubes has a nut molded into the upper body of the sock so you can hold it from turning while you remove the top nut. I used the impact to loosen the top nut then pushed a 13/16 wrench over the "nut" and went back to removing the top one with the impact. If you strip the "nut" because it is just the soft sheet metal of the shock body, you could spend some time fighting it. You wont likely get a cutting wheel in there anyway. sawzall blade could be snuck in there pretty easily if needed. Installing the 5100's requires that you insert an allen wrench inn the threaded rod and tighten that top bolt with a wrench. That is the most tedious part of the job IMO/ Generally nothing difficult about this at all.
Old May 9, 2022 | 05:16 AM
  #30
Leardriver's Avatar
Leardriver
That sounds tolerable. I have a lift that will hold a Super Duty. I know that is cheating, but if I have a marathon day installing shocks, a B&W gooseneck, and airbags, it eliminates a lot of bending and crawling.
