Transfer tanks that work with bed camera system.
Old May 4, 2022 | 09:28 PM
Kameron Rice's Avatar
Kameron Rice
I got an f250 crew cab short bed, with the 5th wheel prep. I tow a gooseneck, and want to install a diesel transfer tank. I would like at least 50 gallons. But I am having issues finding one that will work to where I can still see the gooseball. I like the transfer flow 50 gallon tank, but I don't think I can see the gooseball. Anybody with shortbeds have a tank that works with the camera?
Old May 4, 2022 | 11:17 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You won't be able to see much no matter what.
I have the bed camera and the detail is terrible, hard for me to see anything much of even my 5th wheel when trying to hook up.
Old May 5, 2022 | 06:05 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
RDS makes skinny tanks. Something 9.5" deep might not interfere with the camera:
Old May 5, 2022 | 11:13 AM
Kameron Rice
Just took measurements, I do believe this one will actually work with the camera. Only one that i have seen that will potentially work
Old May 5, 2022 | 11:54 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Check the measurement between the bed corner reinforcements at the floor, it gets very tight getting an aux tank in there.
Those measurements on those tanks listed don't include the mounting tabs, they stick out about 1.5" or so on each end.
Old May 5, 2022 | 12:03 PM
Floral Industries's Avatar
Floral Industries
Another option would be to add an additional bed camera at 90 Deg. to see the hitch location. Here's a tuber where I got the idea. It might give you more options for the tank configuration instead of relying on the stock cam.
Old May 5, 2022 | 12:15 PM
KeystoneF350's Avatar
KeystoneF350
Another option is to put a mirror on your trailer near the gooseneck coupler/pinbox. Similar to this:
Old May 5, 2022 | 12:57 PM
water_junky's Avatar
water_junky
Check out ATTA, I have had their tanks in two of my trucks and they are great. They come in all kinds of sizes and will even custom build them for you.
https://www.attatank.com/
Old May 5, 2022 | 05:46 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
This one looks perfect:
Old May 5, 2022 | 10:02 PM
Kameron Rice
yes, I considered the side brackets, but I will just cut them off if they don't fit. If I bolt it down I will use the front and rear brackets. But I don't want to put holes in my floor if I don't have to so I am thinking about strapping it down to the bed hooks on the front of the bed.
Old May 6, 2022 | 01:17 AM
UKDude's Avatar
UKDude
Have you considered a larger main tank, I think transferflow is making some 60gal main tanks now?
Old May 6, 2022 | 06:44 AM
Kameron Rice
I have to have an external pump so I can fill up my excavators and loaders.
Rob89
Oct 5, 2021 03:41 PM
hoosierbill
Feb 11, 2019 08:39 PM
carl2591
17
Apr 20, 2015 09:33 AM
XBAJBUSX
May 15, 2010 07:10 PM
