Reverse camera trigger
Old May 4, 2022 | 06:00 PM
kevinv10's Avatar
kevinv10
1994 F250, E4OD.
Reading directions to install a backup camera. It has a wire coming from the RCA plug that is for the "monitor trigger". Based on its length, I am assuming it is somewhere in the cab.
​​​​Any idea where?
Thanks
Old May 4, 2022 | 06:20 PM
SFaulken's Avatar
SFaulken
Probably needs to come off the same connector that goes to the MLPS, and toggles the reverse lights, when you put the transmission in reverse.
Old May 4, 2022 | 06:24 PM
kevinv10's Avatar
kevinv10
I appreciate the@SFaulken , but, could you be more specific? Which wire. I am not very familiar with the MLPS switch.
Thanks
Old May 4, 2022 | 07:49 PM
SFaulken's Avatar
SFaulken
I have no idea. I don't own anything with an E4OD, nor do I have a EVTM for a truck with one. I'm sure one of the guys here does, and will chime in when they've got a minute.
Old May 4, 2022 | 08:20 PM
R&RFord's Avatar
R&RFord
There is a connector behind the parking brake assembly for auto dimming mirrors and illuminated vanity mirrors, that should have a branch of the the back up light circuit for the mirror. The correct wire should be black with a pink stripe if I remember correctly. The connector is unused on most pickups, and would be a good location to tap the circuit. Subford or one of the others should be able to confirm.
Old May 5, 2022 | 10:24 PM
kevinv10's Avatar
kevinv10
Do you mean behind the kick panel? Or an actual wire connection tucked up on the dash behind the parking brake?
Old May 6, 2022 | 03:29 PM
R&RFord's Avatar
R&RFord
It is behind the driver side kick panel, behind the parking brake assembly.
n4rpd
May 12, 2020 08:32 PM
Firemanjaxfla
Dec 6, 2019 02:20 PM
78fordman
Jan 11, 2014 10:45 AM
Mstewart
6.7L Power Stroke Diesel
Jul 10, 2012 10:24 PM
kellyb
Jan 8, 2002 01:52 PM
