96 f350 5.8 dually dump truck. Redoing my rear brake lines and the only way to get the flare nut out of the RABS was to take the RABS fitting out. After clamping the fittings in my vice I was able to get the two apart. Now I can’t get the fitting back in the RABS. The threads are fine but won’t catch. It seems to be the rubber gasket stopping it. Has anyone ever had this issue? Will loosening the Allen head bolts on the end of the unit release the gasket enough to get it back in?
Jas88 was suggesting to completely remove the RABS hydraulic module. Several folks on this forum do not like the RABS system on these trucks. I have had no issues with it so I personally have replaced that module before to restore proper operation. Trust me, it is not a $20 sensor.
On my 94 simply unplugging the ABS module behind the glove box disables it and all lights etc associated with it. As a bonus it often corrects speedo needle jitters since it shares the same signal from the VSS. I've done this on 2 trucks and will do it again on the next one that has a problem related to it.
I unplugged mine for a little while and it seems like it made it idle a little higher and took a little longer for the rpms to come back down when coasting in neutral (5 speed). Plugged it back in and it was better. Truck still idles higher than I’d like though
