Sponsored by: Real Truck
BFG A/T Pressure Question
Old Nov 8, 2003 | 12:17 PM
cterrysgd's Avatar
cterrysgd
Just installed my new BFG 285/75/16's and love them so far. Great in the rain and great on the road. Decided to tackle the field i got stuck in two weeks ago with the Firestones. I aired down to 35 lbs all the way around and went right through the field in 4 wheel. Got brave and took it out of four wheel and it still flew through the field. It's a little bit colder than it was the night i got stuck and it stopped raining yesterday. It was raining the night I got stuck. I was shooting all kinds of mud and grass out the back of the truck. I actually had fun this time!
My question is what pressures I should run for different circumstances.
I'm happy with 50lbs all the way around for highway driving.
Mud? 35lbs like I had today? seemed to work well. Can i go lower without damaging the tires?
Sand? lower than 35lbs?
Snow? 35-40lbs?
I wouldn't care about dropping the pressures in a lighter truck but the X weighs so much i wants to get some advice.
Thanks!
Old Nov 8, 2003 | 04:33 PM
user 708242442's Avatar
user 708242442
I run mine at 60 at all times.
Old Nov 8, 2003 | 05:41 PM
cterrysgd's Avatar
cterrysgd
King Ranch,
Is it bad to run lower pressures? Or is that just your preference?
Thanks!
Old Nov 8, 2003 | 09:56 PM
superdutyaz's Avatar
superdutyaz
On the beach I run 15 lbs.(about 20 in my trailer)I have 50 for towinf about 40 unloaded,Mark
Old Nov 8, 2003 | 10:38 PM
MountainHound's Avatar
MountainHound
I keep mine (BFG 285s) at 55psi fronts and 65psi rear. BFG's max rating for these tires is 65psi.
In the winter I air them all down to 45psi for better snow traction because I don't do any towing in the winter months.
Old Nov 9, 2003 | 04:08 AM
user 708242442
I wouldn't go below 30 #
Old Nov 9, 2003 | 01:16 PM
Munkey's Avatar
Munkey
I've got 295's, and running unloaded on the street, I'm at 45 front, and 40 rear. I do this so the whole tread can contact the road. In sand I've gone down to 20 and didn't even have to shift into 4wd. For mud, I usually leave the tires the same as the street pressure, unless it's really bad, then I'll drop to 30.
Old Nov 12, 2003 | 01:10 PM
Rebel03's Avatar
Rebel03
I have the same size as Munkey, and I also run 45psi front and 40 psi rear unloaded.
