rear seal
Old Apr 30, 2022 | 05:24 AM
chuck172's Avatar
chuck172
rear seal
How common is a rear seal oil leak on a 1989 f250 with a 5.8? I've heard it is very common.
I have an 89 in good shape, with only 60,000 miles. Problem is the truck has sat for quite a while. I really only need it for snowplowing my 800' driveway, I've recently been working on it, fixing brake lines, power steering hoses. fuel lines etc. I don't want to dump time and $$ into it if a bad seal is likely.
Old Apr 30, 2022 | 05:58 AM
Robfinger's Avatar
Robfinger
Well if/when it starts weeping out the rear main, you just to off the oil periodically and go about your business. All of these engines eventually develop a rear main leak (hell front one too but that's easier fix), unless it's an Exxon Valdez type of failure (never seen or even heard of one) it's just a nuisance and not much more.
What you should be more concerned about is your transmission, plowing is rough on them. I hope you're using your transfer case's low range while pushing the snow, that extra gearing helps a lot with transmission loads.
Old Apr 30, 2022 | 11:01 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
The truck is nearly 35 years old...so is any factory installed rubber. It shrinks and leaks. Replace it or let it leak as there is nothing else you can do.
Old Apr 30, 2022 | 02:38 PM
chuck172's Avatar
chuck172
I guess your right, a little leak I can live with.
domino1a
2009 - 2014 F150
Oct 9, 2019 11:25 PM
Ford SD
Mar 21, 2016 08:02 PM
tom from mass
Mar 13, 2016 02:12 PM
BigBlue92
May 8, 2011 05:57 PM
95250mac
Apr 26, 2011 04:08 PM
