Searching for a flywheel
Old Apr 30, 2022 | 04:17 AM
rsmiththethird's Avatar
rsmiththethird
I am looking for recommendations for a flywheel for my 1973 Ford Truck F100 1/2 ton P/U 4WD 3.9L 1BL OHV 6cyl
I have search my local parts folks as well as the internet to the best of my
ability without success.
Any suggestions?
Much appreciated
Rick, Mount Airy, Maryland
Old Apr 30, 2022 | 08:56 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Don't know if this will help you or not, but the original part number is C5TZ-6375-N. That's a flywheel that fits the '73 240 cu in (3.9L) straight six.
I couldn't find any OEM or aftermarket applications that fit except this one (https://www.summitracing.com/parts/m.../1973#overview) The application info says that it fits the 240" six but the specs also say its for an internal balanced engine. I thought (I may be wrong though) that the 240 was external balance. If you scroll down to the bottom of the listing, it shows a replacement counterweight kit for the flywheel for uses that are external balance.
If you can't find anything else you might give Summit a call and see if this one will work.
Highboy4x4
Aug 15, 2009 08:36 PM
medicpg
Nov 18, 2003 07:17 PM
