Camshaft Suggestions
Old May 1, 2022 | 12:45 PM
rock2610d's Avatar
rock2610d
Yes, I used it.
It's odd though, because with a 106 ICL and a 112 lobe seperation the cam says its ground with a 6 degree advance.
is that 6 camshaft degrees or 6 crankshaft degrees?
The walace calculator does not say which to use.
I think it's crankshaft degrees because the if I use a degree wheel it's hooked to the crankshaft.
So, 106/112 means 6 degrees (at crankshaft) advanced? That means 3 degrees advance ground into cam in cam degrees, right?
if so I doubled 6 in my calculator which is wrong. It's only 6 degrees which works with the numbers you gave me.
Thank you for your help!!!
Old May 1, 2022 | 01:01 PM
6 by 8's Avatar
6 by 8
I just played around with the Jeep Strokers calculator and I now see where you get the 6* advanced from.
Hmm, funny way of doing it.
Anyway, they state that it's crankshaft degrees, and I didn't pay any further attention.
You can use that calculator again, but this time type in 57 in the IVC block (bottom left), which bypasses the LSA etc blocks.
The DCR won't change when you change the altitude figure, but the DCR at altitude will, which is correct.
I found your Lunati cam, but they don't show the cam timings. Not to worry, 57* is the actual IVC number.
When you fit your cam, use a degree wheel to verify the cam timing events. Imperative that you do this.
You're very welcome.
Old May 1, 2022 | 01:14 PM
rock2610d's Avatar
rock2610d
I have the camshaft data @.050
Exhaust open @ 48 degrees
Exhaust CL 118 BTDC
exhaust closes @ 9 BTDC
intake opens @ 1 ATDC
intake CL 106 ATDC
Intake closes @ 32 ABDC
Exhaust Area 23.2
intake Area 22.3
overlap -9
This is all @.050
Data from
https://mgispeedware.com/camshaft-calculator
Old May 1, 2022 | 01:47 PM
6 by 8's Avatar
6 by 8
Here's the camshaft data at 0.006'' :
IVO 25
IVC 57
EVO 73
EVC 17
SFaulken
16
May 5, 2021 04:21 PM
madrockwyo
Mar 3, 2015 01:04 PM
robertbourque
Feb 1, 2007 02:24 PM
wvbogger
Aug 6, 2006 02:06 PM
pcullins
36
Sep 4, 2004 01:24 PM
