Sponsored by: Real Truck
2003 f 250
Old Apr 29, 2022 | 05:26 PM
Ljellum's Avatar
Ljellum
2003 f 250
I have a 2003 f250 with a 5.4 motor I want more power any one got any ideas.
Old Apr 29, 2022 | 05:46 PM
bajaphile's Avatar
bajaphile
Maintenance first... Clean MAF, air filter, throttle body, PCV, check for vacuum leaks, new plugs, check coils and boots, replace fuel filter.
Apparently people really like the 5 star tuners... do some searches on that.
Old Apr 30, 2022 | 05:24 PM
irydasteelhorse's Avatar
irydasteelhorse
the only way to make more power with the 5.4 is deeper gears. do a search, there really are no quick fixes for this. youd be better off to sell it and buy a bigger motor or go diesel.
Old Apr 30, 2022 | 09:51 PM
edjunior's Avatar
edjunior
Welcome to the forum. I had a '03 with the 5.4L, and it was the best truck I have had so far. I wish I could have kept it, but I needed more for a 5th wheel. Anyway, you are never going to be able to get enough "more power" out of the 5.4L to satisfy your wants. You will just be throwing money at it and not ever getting what you want. The 5.4L is a great engine, but it is what it is. You want more power, get another truck with a bigger engine. I don't want to badmouth the 5.4L...like I said, it was the best truck I've had so far.
Good luck.
Old May 1, 2022 | 11:01 AM
Tunafish389's Avatar
Tunafish389
Interesting article.. Sounds like money but some good dyno numbers.. That tuning company still in business to might be worth giving them a call if you are really interested in power.. https://www.drivingline.com/articles...turbo-upgrade/
Old May 1, 2022 | 12:08 PM
Old and soft's Avatar
Old and soft
Had my 99 5.4 for 15 years. Good truck, no *****. Bought a 01 with a 7.3. The 7.3 does thing's loping along at 1700 rpm that my 5.4 was screaming at 4500 rpm in second gear to pull off while towing a pop up. The 5.4 got 11.25 mpg hgwy amd 8.5 towing. The 7.3 gets 17.25 and 10.5 towing a tt that weighs twice as much and is 4 times bigger than that popup.
I suspect axle gears will give more ***** for cheaper than engine mods.
TBFGhost
Modular V8 (4.6L, 5.4L)
23
Dec 7, 2010 06:37 PM
Retiredfire
Oct 8, 2010 10:46 PM
Born2DriveFords
1997 - 2003 F150
Aug 31, 2005 07:29 AM
roddz170
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 18, 2005 06:34 PM
93bigbronco
1997 - 2003 F150
Jun 14, 2002 04:00 PM
