2019 SD parking brake
Old Apr 29, 2022 | 02:21 AM
dutch71's Avatar
dutch71
Hi guys. Yesterday I was having a conversation with a guy who owns a 2020 SD. Since this is my first super duty (2019 6.7 Platinum) I was asking him about the pedal parking brake.
I used to own a 2018 F150 equipped with the electronic parking brake. There each time I would engage the parking brake the vehicle would be planted to the ground. As opposed to that now in my 2019 SD when I press the parking brake pedal the truck shows sort of a slack before planting itself to the ground. He told me that’s normal. But he went ahead saying something like “the pedal parking brake is sort of emergency thing should you need it. Because when putting the shifter in PARK the super duty engages the parking brake as well.”
Is that really so?
Old Apr 29, 2022 | 05:20 AM
jade97's Avatar
jade97
My 2022 F250 does NOT automatically engage the parking brake when placed in park. Then again, mine has a manual e-brake pedal and manual release.
Old Apr 29, 2022 | 07:27 AM
cpobst's Avatar
cpobst
Is that really so?
Complete BS!
Old Apr 29, 2022 | 08:04 AM
Gomerpyle's Avatar
Gomerpyle
SuperDuty trucks do not do this.
However, some vehicles do have an electronic parking brake that does set when you shift to park. My wife's Lexus has that option although we don't use it.
Old Apr 29, 2022 | 09:21 AM
dutch71's Avatar
dutch71
Originally Posted by cpobst
Complete BS!
Thanks. Thought so
Old Apr 29, 2022 | 09:42 AM
Pugga's Avatar
Pugga
Is that really so?
Whoever 'He' is in that equation, don't consult them on any automotive matters or let them 'help' you with any of your maintenance or repairs. I get very little movement once I set the parking brake. I use it when hitching up to a trailer on a slope so it keeps the ball right where I want it rather than roll slightly when I put it in park.
Old Apr 29, 2022 | 10:11 AM
4wd6.7L's Avatar
4wd6.7L
While we're on the subject....when you guys press the parking brake does it get to a point where it makes a popping sound, maybe 1/3 way down?
Old Apr 29, 2022 | 10:28 AM
morehouse7's Avatar
morehouse7
No, but last year my drivers side rear was hanging up so I pulled the rotor and serviced the ebrake components. It was pretty bound from corrosion and being dry, I brushed/cleaned/lubed/ exercised everything and was noticeable in the ebrake pedal. Worth doing it every once in awhile.
Old Apr 29, 2022 | 10:32 AM
4wd6.7L's Avatar
4wd6.7L
Mine has done this since brand new. Maybe I should bring it up next time I have to go in to the dealer.
Old Apr 29, 2022 | 10:50 AM
Kameron Rice's Avatar
Kameron Rice
yes that is normal! My 18' f250, and my gmc, and my dads f350 do it as well
Old Apr 29, 2022 | 03:28 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, my parking brake makes a loud "clunk" or pop sound about 1/2 way down.
Another member here had the same issue, and took it to the dealership. They found that the return spring for the pedal was broken.
Old Apr 29, 2022 | 03:40 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Electronic parking brakes are built into the caliper itself. A screw, powered by a motor, clamps down on the brake pads.
Parking brakes like on the SD, use small shoes that press outward on the inside "hat" of the rear rotor...just like a drum brake. Operated with a lever (the pedal) and cables, they don't clamp as well, and their design essentially allows for some movement if not super tight.
RJ sheedy
15
Nov 15, 2016 04:41 PM
fnx4wheeler
Sep 23, 2013 09:04 PM
DWV88
Jun 27, 2010 07:22 AM
