Wiring will depend on your switch.
Another thing to consider is what sort of lamp you will use. Are you going to add a lamp or try and use the existing unit. On my 49 I used my original parking lamps. I took them apart and converted the lamp socket from a single filament bulb to a double filament bulb so that I could retain the stock appearance of the front end.
I should clarify. My truck has turn signals. It has a large black Grote t/s switch with 8 wires. I replaced my gauges and during the process I unintentionally disconnected some wires including the flasher unit. I can’t seem to get the t/s to work now. Also the PO had rewired the truck. So a wire diagram would help.
