Coolant Flush? or Just Replace?
Old Apr 24, 2022 | 07:10 PM
Expy2004's Avatar
Expy2004
Trailering
I have a 2010 F250 with the 6.8L V-10 that just turned 50K miles. I just recently purchased it and I am the 2nd owner and pretty sure it has the original coolant in it. I am going to replace the coolant. I bought 4 gallons of the VC7-B coolant. My plan is to just drain the coolant, refill with distilled water, run it a little bit drain, repeat, then drain and refill with the proper amount of coolant, and top off with distilled water. Is it necessary to run a chemical flush with only 50K miles even though it's 12 years old? Thanks,
Old Apr 26, 2022 | 06:34 AM
JWA's Avatar
JWA
I'd run some of the Prestone cooling system flush chemical through it along with your distilled water refill/drain/flush.
You might also test the existing coolant for its pH level---always interesting to know how well its held up over those years. At just 50K miles though it should test very well even now.
Old Apr 26, 2022 | 05:32 PM
Expy2004's Avatar
Expy2004
Trailering
I thought about that, but I was just wondering if it would hurt anything if i didn't get all the prestone super flush out,
Old Apr 27, 2022 | 04:54 AM
JWA's Avatar
JWA
I did the empty and refill with water three times before adding as much new coolant as would fit in the system. I also drove about 100 miles with fresh water in the system to completely clean anything left behind---only then did I add the new coolant.
I'm fairly sure Prestone et al wouldn't add something detrimental to the cooling system if some bits of it remain behind and mix with new coolant. Do keep in mind the Modular Motors, both V8 & V10 hold a lot more water/coolant than we expect. I'm told the V8's have up to 8 gallons total when properly filled.
Old Apr 27, 2022 | 08:33 AM
Expy2004's Avatar
Expy2004
Trailering
Ok thanks for the reply, I will use the super flush, just happen to have some that I was going to use on my Expedition and ended up getting it done at the dealership instead while they were doing some other work. I think the owner manual list the coolant capacity at over 28 qts so 4 gallons of undiluted antifreeze should cover it. Thanks again.
Jack Scandia
Dec 30, 2011 07:26 PM
north2south006
Feb 7, 2011 11:39 AM
98explorerltd
Nov 8, 2010 08:51 PM
mh5500
Jun 5, 2010 09:14 AM
Rich in CO
Jun 11, 2006 08:13 PM
