Transmission
Old Apr 24, 2022 | 12:45 AM
Isaacd214's Avatar
Isaacd214
Transmission
Good evening I was wondering if I need to do a small fix or replace the whole transmission itself?
So when I put the truck in reverse it goes with no issue at all but when I put it in drive it’s like it’s stuck in neutral until I hit the gas pedal and rev it up high then it kicks into gear and it kicks hard can fill it from the rear differential as well then after a few seconds it repeats until I rev up high again and get it going.
so what should I look at before replacing the whole transmission
Old Apr 24, 2022 | 05:36 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It would be easier for people to help you if you told us what year, model and transmission you have. You mentioned putting it in drive but doesn’t tell us which automatic transmission. Some are all mechanically controlled and some are electronic.
Old Apr 24, 2022 | 07:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
first thing to do is check fluid level. your symptoms sound like low trans fluid.
Old Apr 24, 2022 | 11:14 AM
Isaacd214's Avatar
Isaacd214
I have a 1993 Ford F-150 5.0 4 speed automatic trans
Old Apr 25, 2022 | 11:08 AM
Mikewilde90's Avatar
Mikewilde90
Sounds like it is low on fluid. To make sure you get the right reading make sure the truck is warned up and on level ground. Let us know what you find.
joelswork
17
May 14, 2011 10:07 PM
mnjettr
2009 - 2014 F150
Apr 12, 2010 06:13 PM
Knightrocker
2004 - 2008 F150
Jan 25, 2010 10:30 PM
Robber80
Dec 5, 2007 06:07 PM
95f150v8
Aug 19, 2005 05:32 PM
