2017 F150 Vibration
Old Apr 23, 2022 | 10:23 AM
jrbf150's Avatar
jrbf150
2017 F150 Vibration
2017 F150, 4 door, 5.0L 2WD
I purchased a used F150 and there is a vibration at 47 to 52 MPH. then it goes away. It gets more pronounced when towing.
The front end has no issues, tires are all good and balanced.
U Joints appear to be good, no movement or clunking.
(never had this issue with my 02 F150 with 380K on it)
I saw some posts from a long time ago mentioning rear drive shaft out of balance or pinion out of alignment?
Old Apr 23, 2022 | 10:51 AM
JKBrad's Avatar
JKBrad
Welcome to FTE jrbF150,
What brand and size of tires do you have? You may want to take them somewhere else to have the balance checked. Even then, if there is radial pull or a belt separating, a balance won't cure that. FWIW, Discount tire doesn't do a good balancing job as their machines are calibrated for speed, not accuracy.
Old Apr 23, 2022 | 04:54 PM
SpencerPJ's Avatar
SpencerPJ
I agree, I'd probably have them 'road force' balanced. Costs a bit more, they will figure it out. I once bought new Firestone Destination tires, took 9 tires to get 4 good ones.
95fiveoh
May 4, 2018 10:59 AM
9228.bobcat
2004 - 2008 F150
Sep 21, 2017 08:22 AM
dtvh59
2004 - 2008 F150
May 8, 2006 11:13 AM
MSC
Feb 10, 2006 08:20 PM
Fair 96
Feb 4, 2005 07:08 AM
