Tire tubes
Old Apr 23, 2022 | 07:46 AM
dans 51 f2's Avatar
dans 51 f2
Tire tubes
Is anyone using tubes in their tires? My wheels are rusted at the valve stem hole. I have tried using the biggest valve stem I can find with no luck. Any suggestions?
Old Apr 23, 2022 | 10:33 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Have you tried the chrome valve stems that have a nut behind the rubber part inside the wheel. JEGS are the ones I used. They may seal against a rusted wheel hole.
Old Apr 23, 2022 | 04:26 PM
85e150's Avatar
85e150
If they are rusted there, check the back side areas where there are welds and nooks/crannies etc. Might be time for new(er) wheels.
Old Apr 24, 2022 | 03:25 PM
Indybeer's Avatar
Indybeer
I am using tubes in my tires but I am slso using the original rims with 6.00x16 Bias ply tires
Old Apr 25, 2022 | 03:18 PM
dans 51 f2's Avatar
dans 51 f2
Wheels
What years wheels are compatible to 51 F2 16 inch rims.
Old Apr 25, 2022 | 04:23 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Originally Posted by truckdog62563
The factory wheels used on F-2 models during the Bonus Built years and beyond were made by Kelsey Hayes. The K-H part number for them was 31282, the Ford part number was 7RD-1015B. They are 16" x 6", have 8 lug holes on a 6.5" bolt circle, have .560" of positive offset, have a 4.78" center hole, and have bolt holes that measure 21/32" to accept the truck's 9/16" studs. They will differ from more modern wheels of the same size because their hub cap mounting nubs are on the inner face of the the wheel's center while later wheels have the nubs on the outer face of the center. Finding them shouldn't be too difficult. Finding them close to where you live should be your goal to save on shipping costs. Stu
https://www.ford-trucks.com/forums/9...ml#post8856768
MyF450
Jun 28, 2022 02:26 PM
frysl
All Things Towing
Feb 26, 2020 06:21 PM
shootandfish1
Aug 1, 2009 01:38 AM
evilwayz7
2004 - 2008 F150
May 18, 2009 11:29 AM
jdman1
Nov 2, 2007 08:56 AM
