Keep ECO turned on
Old Apr 26, 2022 | 06:20 PM
Squirrel13's Avatar
Squirrel13
When driving from Denver to Lexington for daughters graduation I used ECO the entire trip. S&B 60g tank cruise at 65-70 I was able to make it on one tank. Truck said 25.2 hand calculation came up with 24.9973.
Old Apr 26, 2022 | 06:32 PM
schrod's Avatar
schrod
What is your rear end ratio? That is fantastic fuel economy!
Old Apr 26, 2022 | 07:28 PM
Squirrel13's Avatar
Squirrel13
Schrod - 2020 F350 SRW 4x4 with 3.31
Old Apr 26, 2022 | 07:34 PM
Squanto's Avatar
Squanto
Sure but that's downhill.
Old Apr 26, 2022 | 07:57 PM
-David-'s Avatar
-David-
Has anyone tried a mpg test in "Sand" mode?
Old Apr 26, 2022 | 08:12 PM
elee3's Avatar
elee3
And a Tremor valence.
Old Apr 26, 2022 | 10:34 PM
TX Chris's Avatar
TX Chris
I drove my truck in Eco mode for the first time today. It felt like I was driving a Prius. I had to switch back to normal after 5 minutes.
Old Apr 26, 2022 | 10:50 PM
Squanto's Avatar
Squanto
So I'm guessing ECO is really only helpful in city driving and probably doesn't do much for you on the highway?
Old Apr 27, 2022 | 07:45 AM
Matt In Detroit's Avatar
Matt In Detroit
Ive tried ECO it around town and on the highway, around town its horrible, makes the truck feel sluggish and disconnected. On the highway it takes more pedal for passing gear kickdown. It seems to soften everything, throttle response, shift patterns. I use it on the highway in case there is a benefit but around town i like tow/haul, it really wakes the truck up.
Old Apr 27, 2022 | 08:08 AM
Buckeye-SD's Avatar
Buckeye-SD
Anyone see an effect on DEF usage with ECO on? My neighbor with a 21MY 6.7 says his DEF usage goes way up on ECO.
Old Apr 27, 2022 | 08:53 AM
Squirrel13's Avatar
Squirrel13
BuckeyeSD - I have no data to support it but ECO seat of the pants feels less efficient delivery of power. My guess is that since the efficiency is less the exhaust would also require more attention via the DEF system
Old Apr 27, 2022 | 11:44 AM
schrod's Avatar
schrod
That makes no sense unless it is mfg more nitrous oxides in ECO mode. DEF is added after the DPF to combine with the nitrous oxides to create water and nitrogen.
Old Apr 27, 2022 | 12:06 PM
  #28
2021F350's Avatar
2021F350
That is the effect of driving like a grandma... The ECO mode tries to do it for you, by making the go pedal less direct. Like you would, if you were actually trying to drive economically... Expecting the truck to drive the same way is as in "N" or "T/H" mode a fail, because if it did drive the same, it would not be driving economically...
Old Jan 1, 2023 | 10:46 AM
  #29
BDWSD22's Avatar
BDWSD22
I do see slight differences in ECO mode
I have a '22 F-350 SCLB 4X4 Lariat 6.7L 11,400 GVWR 3.55:1 Snowplow/Camper pkg., hidden heavy-duty front receiver hitch, heavy-duty grille guard, Tremor front panel and 275/65R20 Michelin LTX A/T2 set at 80F/78R.
So many factors affect mpg that from day to day I average 18.4 to 19.0 mpg with an uncorrected speedo error of 2 to 3 mph. The 2020 STX version of the same truck that I had, when stock could get 25mpg at 55mph. With similar modifications it dropped to 19mpg if I kept my foot out of it. The '22 before mods couldn't clear 21mpg at 55mph on the same route.
I bought my Superduty trucks to work. If I want high mpg, I would drive my 198k miles Altima. I tow an 11k lbs. RV or haul a full bed of gravel while towing a trailer with a skid-steer loaded. Empty though, I use ECO mode. I need to get my onboard air and Superlift bags installed so at max GVWR I won't be piloting a tail dragger.
Old Jan 1, 2023 | 10:58 AM
  #30
BDWSD22's Avatar
BDWSD22
TOW vs ECO mode mpg
Of course, 18.4/19 mpg is 70/55 mph EMPTY.
Towing those heavy loads is in tow mode, auto engine brake on at 8.8/12.5 mpg respectively. I usually take the slow route when towing and take it easy.
