Spark fuel issue
Old Apr 21, 2022 | 11:53 AM
460man68's Avatar
460man68
Spark fuel issue
I have a 1994 f-250 with the 460 in it. It isn’t getting spark or fuel and I’ve tried everything.
replaced the distributor, intuition coil, spark plugs and wires, and fuel filter.
i don’t know if it’s just the battery or if it’s a grounding issue.
how do I figure out if it’s a grounding issue? Do I have to check every ground on the truck or is there a way to look with the ecm?
Old Apr 21, 2022 | 12:15 PM
sandymane's Avatar
sandymane
A fuel pump can not cause no spark. Try unplugging the PCM/ECM and see if spark returns.
Old Apr 21, 2022 | 06:01 PM
kevinv10's Avatar
kevinv10
Not questioning your abilities, but, how did you determine both no spark and no fuel happening at the same time? Any recent work done prior to these issues?
I have the same engine, so I may or may not be able to help. Just need more info, please.
Jerf
Mar 23, 2024 02:40 PM
Mrawesome123455
23
Sep 19, 2021 06:56 AM
Morg89
40
Dec 26, 2012 11:31 PM
1991ford_trucker
23
Jan 24, 2011 06:34 PM
Rothschild
15
Aug 11, 2009 04:58 PM
