HELP Ignition system
Old Apr 21, 2022 | 09:22 AM
martyg1954's Avatar
martyg1954
Does a stock coil from a 1985 Mustang with a normally aspirated 302 5.0 engine have an internally mounted register, or do you have to put an external resistor in the ignition system? My resister has no marking to indicate if it has an internal resister.
i
Last edited by martyg1954; Apr 21, 2022 at 09:27 AM. Reason: i dont like the title help
Old Apr 21, 2022 | 09:28 AM
Franklin2's Avatar
Franklin2
Stock coil does not have a resistor internal. The resistor is in the stock harness of the mustang when they used the duraspark II ignition box. The duraspark system requires the resistor. The TFI ignition system does not require resistor. The GM HEI does not require a resistor.
kyle1979ford
May 23, 2013 06:59 PM
GOTH_TRUCKER
Electrical Systems/Wiring
Aug 28, 2006 09:11 PM
ranchero73
Jul 8, 2004 09:42 PM
judel
Apr 27, 2004 07:55 PM
fordbigtruck
Dec 8, 2003 08:18 PM
