New Rotors!!!
Old Nov 7, 2003 | 10:08 PM
bronco351's Avatar
bronco351
Angry New Rotors!!!
Hi guys, I have a 1998 Expy EB 4x4. I just looked at my brakes today and it turns out I need new rotors.
I was wondering how much all 4 rotors usually cost, also are they hard to install? Should I take it to a brake shop?
I appreciate your help!!
Old Nov 8, 2003 | 09:20 AM
CrumpDogg's Avatar
CrumpDogg
If you have basic mechanical skills and your basic handtools you can do it yourself. A brake shop will try and rape you, so I wouldn't suggest that.
Just pull one of the wheels off, and if you really think it is too difficult, then take it to a shop.
Old Nov 8, 2003 | 09:22 AM
WillieWildcat's Avatar
WillieWildcat
Depending on the rotor make, you can expect to spend between $50 and $90 apiece. They aren't cheap (I replaced my fronts last June for $60 per). It is the actual removal process that will tax you more than spending the money on the rotors.
Old Nov 9, 2003 | 01:13 PM
BigMattXXL's Avatar
BigMattXXL
Re: New Rotors!!!
The main issue here is the removal - they tend to rust to the hubs, making removal a huge PITA. It can be done, but it won't go without a fight.
Make sure you put a bit of anti-sieze where the new rotor contacts the hub.
XXL
Old Nov 9, 2003 | 05:37 PM
1999XLT's Avatar
1999XLT
I agree with Matt,
The removal may tend to be the hardest part. If they are rusted on you better budget a day and some sawzall blades or a sledge.
Old Nov 10, 2003 | 12:01 AM
buzzard's Avatar
buzzard
Mine came off very easily, but don't expect to be so lucky. Do you have a torch or access to one?
My new USA made front rotors cost $48 each with lifetime warranty. Be careful of cheap asian parts.
Old Nov 10, 2003 | 12:20 AM
BigMattXXL's Avatar
BigMattXXL
Originally posted by 1999XLT
I agree with Matt,
If you're feeling studly, though, some PB Blaster and a BFH (that's a big hammer ) should do the trick.
XXL
Old Nov 19, 2003 | 05:08 PM
southprk's Avatar
southprk
PB Blaster + BFH + 2 days = removed right front rotor
BFH + 10 minutes = removed left front rotor
With a lot of mechanic work the idea is to be graceful and all of that stuff.. with expedition rotors get that out of your head -
I took out the studs and just put a sammy sosa on the rotors. Just be careful not to hit the spot in the center of the rotor. Not like I did that or anything but if you do it might make your wheel not slide over the hub, and then you have the grind off the diformed metal around the center..
Old Nov 19, 2003 | 07:06 PM
tyger25's Avatar
tyger25
Would have took 5 min if you used some Mark Mcgwire instead of weak *** Sammy juice....
Old Nov 19, 2003 | 07:15 PM
southprk's Avatar
southprk
MY HAMMER WAS NOT CORKED
Old Nov 19, 2003 | 10:18 PM
bronco351's Avatar
bronco351
Well guys I did the Brakes last weekend!! It was not that hard. The rotors came off very easily. NO rust at all. I guess that's due to it being an Arizona truck.
The whole Brake job including Rotors, pads, brake fluid, and new stainless steel brake lines only cost me... $585.00!!!!
Thanks for all the help guys.
Old Nov 20, 2003 | 09:24 AM
tyger25's Avatar
tyger25
You got lucky! Glad it worked out for you! The price is actually pretty good too.
handye9
Jul 14, 2017 02:24 PM
XCUR&F350
Jun 22, 2017 08:14 AM
Bushwhacker1
2009 - 2014 F150
34
Jan 21, 2017 08:54 AM
Fordperson
Mar 28, 2016 07:30 AM
chazman
Jan 21, 2008 04:14 PM
