Rear Axle ID?
Old Apr 16, 2022 | 06:42 PM
mwebster22's Avatar
mwebster22
Rear Axle ID?
2020 Ford F-350 SuperDuty, SRW 4X4 FX4 Crew Cab Lariat Shortbed 160” Wheelbase, 6.7L PS Diesel 10-Speed 10R140 Automatic, 3.55 E-Lock Axle,
Owners manual says 10.5, 10.8 or 11.8. Not very helpful…
Tag on rear axle picture attached.
Old Apr 16, 2022 | 06:44 PM
jollyrogr's Avatar
jollyrogr
My guess is M275 but post a pic of the pumpkin to confirm.
edit: definitely M275
Old Apr 16, 2022 | 07:01 PM
4wd6.7L's Avatar
4wd6.7L
SRW F-350 w/diesel gets the Dana M275.
Old Apr 16, 2022 | 07:12 PM
mwebster22's Avatar
mwebster22
Thanks. Is it 10.5, 10.8 or 11.8? And does it need friction modifier additive since it’s electronic lock?
Old Apr 16, 2022 | 07:30 PM
4wd6.7L's Avatar
4wd6.7L
The Dana M275 would be the 10.8. No friction modifier necessary.
Old Apr 16, 2022 | 07:36 PM
chadstickpoindexter's Avatar
chadstickpoindexter
My axle code is 3H, which is the 3.31 EL axle (3J is the 3.55 EL axle). I also have the HCTT package, so I know I have the Dana M275 axle, which looks exactly like yours.
Also, the 10.5 is the Sterling axle, 10.8 is the Dana M275 and the 11.8 is the Dana M300.
So no, you don’t need the friction modifier. Just 3.6 quarts of 75W140. Also, the bottom right bolt is the drain bolt. But before you drain it make sure you can remove your fill plug first. I just did mine about a week ago.
Old Apr 16, 2022 | 10:32 PM
alinosa's Avatar
alinosa
This is answered but I noticed something poking around under mine when I too was trying to figure this out: The cover says FoMoCo on it. but if look just to the left (if you're at the rear of the truck and looking forward, the driver side shock mount is stamped with "DANA" as well, maybe this will help someone:
Old Apr 17, 2022 | 06:54 AM
Desert Don's Avatar
Desert Don
Count the bolts in the diff cover. 12 bolts = Sterling 10.5; 14 blts = Dana M275. Easy.
Old Apr 17, 2022 | 09:13 AM
alinosa's Avatar
alinosa
Ahhh. Probably the easiest!
Old Apr 17, 2022 | 10:04 AM
Bldrinker's Avatar
Bldrinker
7.3 with 4:30 get the Dana M275 right?
Old Apr 17, 2022 | 10:27 AM
Grass Lake Ron's Avatar
Grass Lake Ron
Yes, you do.
Old Apr 17, 2022 | 11:39 AM
alinosa's Avatar
alinosa
Originally Posted by Grass Lake Ron
Yes, you do.
Can confirm this as well.
clintonvillian
16
May 9, 2022 04:58 AM
Ferdus
1997 - 2003 F150
Mar 29, 2020 06:56 PM
MOOKIEX4
Sep 3, 2019 10:13 PM
wwchatt
Jun 16, 2018 11:00 AM
1990FRANKENTRUCK
13
Oct 26, 2016 06:53 PM
