Anyone know why, or what to do about a slow driverside power window... Its about 3 times slower than the passenger side! I'm assuming I have to get a new motor or something. Is this somehing covered under waranty, still under 100,000. or is there something I can grease-up. Any help would be awsome!! Thanks guy's.....
Just wanted to say this has been a very informitive site tolearn about the mighty Deisel!!! Haven't posted much and haven't been a member for long but I have been reading on this siite for some while now. Thanks for all the info everyone!! Keep it up!!
just get some SILICONE spray, spry the channel the window rides in.just be careful, the firt time the window goes down it will seem like it is going through the bottom of the door . i like to use crc brand,but have used prestone silicone spray with good results also.
Ok.. I'll try the silicone spray since I already have a can of it, just seems messy... Do I have to take the inside panel off to lube, or can I just spray down the sides? All the help is appreciated, Thanks again!!
