1988 E250 broken into: plexiglass driver window?
Old Apr 14, 2022 | 12:26 AM
alvisedt's Avatar
alvisedt
Angry 1988 E250 broken into: plexiglass driver window?
Hello everyone!
(My van is a 1988 E250, Custom trim if I'm correct)
Today I found out someone broke into my van and they destroyed the driver-side window. I am thinking about how to replace it and I have two questions:
1) This website lists what looks like a good replacement for ~40$ which seems great, do you guys think is a safe site / thing to buy from them? https://www.carparts.com/door-glass/...ent/repf480131
2) Would it be very crazy to try to replace the broken window with a plexiglass sheet instead? I could probably take the shape from the passenger side and at least it would be less prone to be shattered and broken like that.
What do you guys think? Would love to know some reasons why this is a stupid idea and/or if anyone tried, etc..
This is the broken window
Old Apr 14, 2022 | 04:02 AM
JWA's Avatar
JWA
Using any sort of "plastic" sheet whether Lexan (poly carbonate) or Lexan (acrylic) is NOT a good idea as it will become highly scratched in very short order. Since it moves up and down and rubs against the door run channels etc. You're welcome to try but cutting the right shape so the replacement piece fits correctly would be tough using the installed passenger side glass.
I'd suggest you call a local independent glass installer and get a quote on them doing the job completely or see if they'll sell you just the glass for DIY. Since I'm already in the auto/truck glass business I'd pretty never use an on-line glass seller due poor fitment and possible breakage while in transit.
Good luck with this!
Old Apr 14, 2022 | 06:58 AM
manicmechanic007's Avatar
manicmechanic007
Pretty easy to replace the glass
A junkyard window should be about 25 bucks
If I installed it for you it would be about 90 bucks
Sleep light and with a gun
Old Apr 14, 2022 | 12:54 PM
T-wood's Avatar
T-wood
Jwa is right about plexi or lexan. Lexan being the most scratch resistant it still shows marring and the glare is terrible. You would hate it.
It does work easy. I cut and route it with wood working tools. But lexan isn't cheap.
The quickest cheapest option is the salvage yard. I install them in the parking lot just so i don't break them on the drive home.
Old Apr 15, 2022 | 02:48 AM
alvisedt's Avatar
alvisedt
Thank you folks, I'll update once I make progress!
Old Apr 15, 2022 | 08:15 PM
annaleigh's Avatar
annaleigh
IF you have trouble finding the glass locally, here is a place to look and most all of the yards will ship to you..
https://www.car-part.com/
Chris1989
May 31, 2021 08:44 PM
mccullek
Feb 17, 2018 04:46 PM
annaleigh
Dec 30, 2015 06:52 AM
green bean
Aerostar
Jun 27, 2010 05:26 PM
