Pushrods for 400 w/roller cam
Old Nov 7, 2003 | 08:45 PM
danlee's Avatar
danlee
Question Pushrods for 400 w/roller cam
I know that there are a few here that have converted to Roller cams in their 400.
What length pushrods are you using?
I have roller rockers and guideplates as well. My present pushrods are hardened. I think that I will need new shorter hardened pushrods.
Old Nov 7, 2003 | 09:44 PM
Brian S's Avatar
Brian S
How about a low buck tool
There can be a lot of variables. It's best to check for yourself.
http://www.fordmuscle.com/archives/2...ps/index.shtml
Old Nov 8, 2003 | 08:00 AM
danlee's Avatar
danlee
My present pushrods are 5/16 hardened chromealloy 9.5" long by Trick Flow. I think that roller lifters will reduce that by 0.604" to 8.896".
Trick Flow sells a 5/16 hardened chromealloy pushrod in 0.050" increments up to 9.0". I should be able to use 8.90" pushrods. I think that I will wait until I have everything assembled and check using a home made checker like in that article.
Old Nov 10, 2003 | 05:16 PM
beartracks's Avatar
beartracks
You will need shorter push rods. I would suggest using the cam makers push rods and checking them for proper length/geometry.
Old Nov 11, 2003 | 08:57 AM
HawkeyeF100's Avatar
HawkeyeF100
Hey BEARTRACKS , where did you find a overdrive for your 77 ?
How much modification did you have to do???
'78 F100 Ranger XLT 2WD 400 Auto
Old Nov 11, 2003 | 02:10 PM
beartracks's Avatar
beartracks
Most of the modification was to my wallet! It's a Gear Vendors and involves removing the tail shaft housing and shortening the drive shaft. Excellent unit but not cheap.
