Stock ride height?
Old Apr 12, 2022 | 07:09 PM
obiwan kenobi's Avatar
obiwan kenobi
Stock ride height?
Just acquired this 2017 F250 platinum and I'm curious about the ride height, doesn't appear to have any spacers up front and the rear springs have ford part numbers. I'm curious as I want to move up in tire size and need to know if a lift is needed to run 35's off road without rubbing?
Old Apr 12, 2022 | 08:02 PM
GG386's Avatar
GG386
Sure looks leveled to my eye. Some leveling kits don't use a spacer, the springs get replaced with taller ones with those
Usually you can tell by looking at the brake lines and/or some non-factory components living in the front suspension
Old Apr 12, 2022 | 08:13 PM
HRTKD's Avatar
HRTKD
Maybe it has the snow plow prep package? That has the stiffest springs. It's like a poor man's leveling kit.
Old Apr 12, 2022 | 08:21 PM
Ding126's Avatar
Ding126
put 295's on so there's no rub.
Old Apr 12, 2022 | 08:51 PM
Joe T's Avatar
Joe T
295/65/20 or maybe 37x10.50?
Old Apr 12, 2022 | 10:30 PM
Sonny Crockett's Avatar
Sonny Crockett
I think you meant 11.50. I've never seen a 37 x 10.50. I don't think 35's will rub but a 37/12.50 will. 37/11.50, probably not.
Old Apr 12, 2022 | 10:56 PM
4wd6.7L's Avatar
4wd6.7L
It does look like it has some sort of lift up front. Could you post a picture or two of the front suspension?
Old Apr 12, 2022 | 11:47 PM
willynilly's Avatar
willynilly
looks nose high to me but could be camera distortion
Old Apr 13, 2022 | 07:29 AM
Joe T's Avatar
Joe T
It does look high.
Stock shocks? Looks like rancho rubber boots up front? If stock change them.
Look at the bottom of the spring perch up front for a spacer. If no spacer post photos of the springs. Looks like a 2 inch or more level kit.
If you have more than 1 inch lift you probably need to make sure caster is adjusted. More than 1.5” and the trackbar needs a spacer bracket or adjustable unit.
Old Apr 13, 2022 | 09:26 AM
obiwan kenobi
Brake line brackets appear to be factory
No drop bracket on track bar
Rear shot of springs and shocks
Old Apr 13, 2022 | 09:34 AM
redford's Avatar
redford
FTE Leadership Emeritus
I'd bet that you have the snowplow prep package.
Old Apr 13, 2022 | 09:35 AM
kylant's Avatar
kylant
it has a level spacer below the lower spring perch.
that round spacer is not factory. that spring perch sits down on the knuckle from the factory
because of that, those front shocks are overextended and probably topping out during rebound
Old Apr 13, 2022 | 01:52 PM
Joe T's Avatar
Joe T
Yeah it has a spacer (looks 2 inches) and looks to have a trackbar drop bracket. Looking off my phone.
I would suggest 2 degree caster shims (if not installed), shocks that work with your spacer height, and a quality steering stabilizer. Check everything else for wear.
All easy stuff and will make the truck drive well.
At least 295/65/20 height. Maybe 325/60/20 height or 37s.
93f2504X4
Jul 24, 2024 12:23 AM
Swamp_Yankee
Apr 21, 2018 08:18 AM
08mike250
Jan 28, 2012 09:15 AM
seanvicious
May 8, 2006 05:24 AM
