Reusing Intake gaskets
Old Apr 10, 2022 | 06:26 PM
Droopy390's Avatar
Droopy390
I recently purchased a fel-pro gasket kit for my 390 part number ft 8554 pt because I thought I had an intake manifold gasket leak, I took the motor apart and then realized I actually have two broken valve springs, (the valves somehow didn’t fall into the combustion chamber) (exhaust on 3 and 6) I’m doing the job outside and it’s still fairly cold where I live and didn’t want the internals to be exposed to the condensation so I closed up the motor using my new intake gaskets but will have to go back in and take the heads off to do the springs and lap the valves could I reuse the intake gaskets or are they done for ? All I did was torque the intake manifold, i didn't fire up the motor
Old Apr 10, 2022 | 07:01 PM
f5fordgirl's Avatar
f5fordgirl
Depends on what their make of, if you torqued the manifold down tight, when you take it off pieces of the gasket may pull off, and not sure if they have a squish margin, I'd go with a new set.
Old Apr 12, 2022 | 04:59 PM
KO1960's Avatar
KO1960
Especially if you have a cast iron intake. You only want to set that once.
mytoolman
Oct 1, 2019 06:35 PM
asmith6
Nov 30, 2007 09:35 PM
FalconStng
Jan 28, 2006 12:25 PM
Rusty Trusty F-150
Jun 1, 2004 11:04 PM
mwkobe
Aerostar
Oct 23, 2003 11:26 PM
