power door locks
Old Apr 10, 2022 | 06:04 PM
patrickg450's Avatar
patrickg450
power door locks
good evening,
My 250 is an 03 quad cab, both of my rear doors locks are sticking. Meaning that when the unlock button is pressed the lock moves up, ( I can see it ). But not enough to unlock the door, I took off the panel and thought it would be an easy clean and oil job. But I don't think that is the case, there is some slack in the pivot points that I think is causing the issue. Being 20 years old and not wanting to damage this plastic clips and small parts I thought I 'd ask here before tearing them apart.
IS there a common failure item or known issue? Also good source for these PITA parts would be helpful.
thanks fellas
Old Apr 16, 2022 | 06:46 AM
torq'ta 5 8's Avatar
torq'ta 5 8
03 totally different body style than 04-08, but usually get the plastic clips, at parts store, in the help section.
May get more help from here-->1997 - 2003 F150 - Ford Truck Enthusiasts Forums
jrank
Aug 14, 2009 08:07 PM
n5926g
1997 - 2003 F150
Mar 22, 2009 07:19 PM
PSDLOVER
Nov 29, 2004 05:27 PM
