92 300 i6 acceleration issues
Old Apr 10, 2022 | 12:17 AM
jayu's Avatar
jayu
Have a 92 f150 4.9 straight six truck cranks and turns on fine revs good in neutral no fuel starving whatsoever new fuel pump and fuel filter new spark plugs good rotor and distributor cap new 14lb injectors maf sensor replaced ran through all vacuum lines and changed all rotten broken ones but the issue is whenever I put it in gear it buckles and jerks and acts as if it is fuel starving and cuts off but will stay on if put back in neutral any advice or help ?
Old Apr 10, 2022 | 06:43 AM
My4Fordtrucks's Avatar
My4Fordtrucks
No fuel starving issues verified with a mechanical pressure gauge? Are there any active or stored fault codes from the KOEO self test?
Old Apr 10, 2022 | 01:46 PM
jayu's Avatar
jayu
Good fuel pressure at 43 psi exact nothing coming up on code test noticed if map sensor disconnected idles high but has no starving issues but it is strange because I replaced it already
Old Apr 10, 2022 | 06:40 PM
My4Fordtrucks
That’s too low.
Jbickel
Mar 28, 2022 09:08 AM
89straight6
Mar 11, 2010 01:07 PM
BigChief
Feb 17, 2005 12:41 AM
truogj
Aug 9, 2003 10:34 AM
slpj
Oct 13, 2002 06:18 PM
