power running boards
Old Apr 8, 2022 | 05:31 PM
strtcop1's Avatar
strtcop1
About a year ago I installed factory power running boards in my 2017 F-350 sd . at first I had a few problems that I was able to cure.
My problem now is that they work fine for a while, then intermittenly shut themselves off for whatever the reason.
Sometimes I can turn them back on from the dash but some time I cannot.
So I leave them alone and drive for a while and they turn themselves back on????????????????
Anyone have any suggestions..
Thanks
Ron
Old Apr 8, 2022 | 05:37 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Loose or corroded connectors ?
Old Apr 8, 2022 | 06:41 PM
rhino_160's Avatar
rhino_160
Thanks
Ron
start simple and cheap. Grab you some electrical connector spray and electrical grease from the parts store. Unplug all the connections, spray them heavily and clean as needed. Once dry, put the grease on them and plug back in.
could be as simple as moisture in a connection that’s drying out and getting wet depending on the conditions. Best of luck
strtcop1
Oct 17, 2021 11:56 AM
Xsuperdutyfan
Sep 9, 2021 04:21 PM
seabass72
May 16, 2021 07:54 PM
strtcop1
May 1, 2021 05:03 PM
Caveman2851
Aug 9, 2016 02:27 PM
