vibration... need advice asap
Old Nov 7, 2003 | 04:24 PM
toml98's Avatar
toml98
Last night my pickup began a strange vibration when I was driving on a 150 mile trip. I took it in this morning, had the balance on the tires checked and it is still doing it. The vibration doesn't occure until about 57 mph. I think it may be a U-joint, but i'd like any other opinions you all may have. BTW it's and '83 F-150, 4.9L, T-18 four-speed, Ford 8.8 rearend. Thanks a bunch.
Old Nov 7, 2003 | 05:32 PM
locknkey's Avatar
locknkey
Have you check the wheel bearing?
Old Nov 7, 2003 | 06:07 PM
Bargod's Avatar
Bargod
Could be that you are slightly out of alignmnt, the balance job prolly wouldn't fix that.
Old Nov 7, 2003 | 10:15 PM
plowpusher's Avatar
plowpusher
if it just started check the u-joints try putting it in neutral see if it goes awaywhen you hit speed
Old Nov 24, 2003 | 09:05 PM
toml98's Avatar
toml98
Thanks
Thanks for all the input. Problem turned out to be the front U-joint. Not a bad fix, just bad timing.
Old Nov 28, 2003 | 11:40 AM
Timken's Avatar
Timken
You also can get some vibration from worn I-beam arm bushings.
