2017 APIM Troubleshooting
Old Apr 3, 2022 | 11:32 AM
Danny1787's Avatar
Danny1787
On my 2017 F350 (XLT), the screen went blank when I started the truck (ironically, while leaving the Ford dealer for parts for my '95). This has happened in the past and has come back to life after stopping and cycling the key. As I was crunched for time, I drove about 30 minutes with no screen, then stopped, expecting the screen to wake back up when I started again. However, it did not wake up. I have since checked the fuses, tried soft resets, and done overnight battery disconnects, still no signs of life. It has been a week and a half now.
Yesterday I pulled the APIM and checked resistance on the unit between pins 8 (+12v) and pins 37/38 (grounds), the result was open loop on one of the ground pins, I should have wrote what I found on the other, because now I dont remember. I am not sure which ground pin I should be checking, either.
On the harness side, I found 14.5v (with the key on) between pin 8 and one of the grounds (37/38), and nothing on the other ground.
In my limited understanding of electronics, I believe I have a bad unit on my hands and it is not a power issue. Does anyone have any guidance on a proper procedure to check the unit or vehicle in this scenario?
Thanks in advance!
Old Apr 3, 2022 | 12:58 PM
mwheue's Avatar
mwheue
Attached page 42 might help? If I can get it to upload....
Old Apr 3, 2022 | 01:24 PM
sleddinfool's Avatar
sleddinfool
Apim all day long. Always have been garbage, always will be garbage.
CalebW
Mar 12, 2021 10:19 AM
zerocool420
Nov 8, 2019 11:35 AM
1990dw
Apr 20, 2018 12:28 PM
JonnyRam
Nov 11, 2016 03:46 PM
