2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Accessing backseat in Supercab
Old Apr 2, 2022 | 09:05 PM
Binkowski's Avatar
Binkowski
Hi all,
So I've watched more than a dozen Youtube videos that report to show me how to access the area behind my backseat on the drivers side. I've seen the aftermarket brackets/straps, and the homemade paracord mechanisms. But I still can't figure out how to release the seat. In a Supercab the back of the seat does not move forward, away from the rear wall when you lift the bottom portion of the seat. I have found no way that works that gives me room to reach the lever to release the upper portion of the seat. I've tried a coat hanger, a wrench, a plastic flexible rod with a notch cut out. Other than stuffing things in from the passenger side, I can't access that area. So, how are you all doing it?
Old Apr 7, 2022 | 03:07 PM
bigred460ci's Avatar
bigred460ci
Yes that is correct the seat back does not move forward when you lift the bottom of the seat on the Supercab.
I was able to reach down with a box wrench hook it on the release and pull up without much issue.
Old Apr 7, 2022 | 08:13 PM
Binkowski's Avatar
Binkowski
Thanks bigred. I'll keep trying. Where you at in Western Mass? I used to live in Hadley, MA.
Old Apr 8, 2022 | 12:08 AM
85e150's Avatar
85e150
The OEM little fabric or nylon pull is hard to get to. I rigged mine up with a wire. Looks like poo but cheaper than the Built Right release. I have a bunch of stuff behind that seat.
Old Apr 8, 2022 | 06:39 AM
bigred460ci
I live in Granville.
KCRebel
Dec 16, 2020 08:40 PM
jspringator
Jul 25, 2015 11:37 AM
jd58980
Sep 3, 2013 06:45 AM
FixrUpr
Apr 9, 2008 10:05 AM
John7894
Oct 24, 2003 02:36 PM
