460 Motor Plate Question
Old Apr 2, 2022 | 09:03 PM
79F150400M's Avatar
79F150400M
Are they the same? Auto vs 4spd.
Im guessing this one was modified by cutting off the area around the starter. I have another plate but it's from a auto...just want to confirm so I don't waste my time. TIA
This is the other one. Can't figure out why the PO trimmed it.
Old Apr 2, 2022 | 09:38 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Nope, auto plates are different from manual plates.
Old Apr 2, 2022 | 09:51 PM
79F150400M's Avatar
79F150400M
Thanks for the info. Do you know what I need? A plate off a 351M/400??
Old Apr 2, 2022 | 09:57 PM
ranger140892
Grumpy goat
400, 351M, 429, and 460 all use the same mid plates. The difference between manual and automatic transmission mid plates, is where the starter is located. Manual transmission has the starter farther outboard than where the automatic transmission locates the starter.
Automatic transmission mid plate:
https://shop.broncograveyard.com/Mot...uctinfo/20702/
Manual transmission mid plate:
https://shop.broncograveyard.com/Mot...uctinfo/20700/
Old Apr 3, 2022 | 12:36 AM
Doosenberry's Avatar
Doosenberry
This is the plate off my old 351M in my Bronco. It's being used with a 460 now. NP435 transmission.
Old Apr 3, 2022 | 09:57 AM
79F150400M's Avatar
79F150400M
Thank you all for the info...I think I figured out why it was trimmed. Trans was swapped out for a T19 and I'm guessing they didn't know that the motor plates were different so instead of tearing it apart...they just cut it. I'm glad I asked...I didn't know they were different.
I'm going to order one from Jeff's Bronco.
Do I need a different starter?
Old Apr 3, 2022 | 11:11 AM
ranger140892
Grumpy goat
Starters don't differ. Yours will work.
Yeah, trimming the plate so the starter will clear is definitely not the answer. The plate does more than position the starter, it also supports, spaces, and aligns the starter. With that big notch cut out, the starter will be off axis once the two bolts are torqued down. At the very least, that would cause the starter to misalign with, and chew up the ring gear.
Old Apr 3, 2022 | 12:01 PM
79F150400M's Avatar
79F150400M
Well...I got lucky as there doesn't seem to be any chewed teeth on the ring gear.
Old Apr 3, 2022 | 12:05 PM
ranger140892
Grumpy goat
Yep, count your blessings. And pat yourself on the back for being smart enough to dig for information.
psquare7575
Ford Truck Parts for Sale
Dec 17, 2012 07:05 PM
Highboy74
Apr 16, 2012 09:04 PM
6863m
Dec 6, 2010 07:00 PM
68FORD
Mar 24, 2002 05:11 PM
