69 f100 2wd 240
Ordered new inner/outer tie rods and adjusting sleeve. The outer I received is different from the existing. Wondering if it would still work. Has the right length. Or is it the wrong part?
appreciate the help.
I just replaced my driver's side outer tie rod this weekend, and it looked exactly the same as your new replacement. Part was Moog DS736. Looked like the old one on the truck and fit perfectly.
Looking at your original, the head being angled in the other direction would make me 2nd guess myself too, but perhaps all it would mean is that it sits at a slightly different position in the radius arm hole. Mine sits kinda at the back. Your original probably sat in the middle or the front of the hole.
