Water Pump
Old Apr 1, 2022 | 10:24 AM
RTT's Avatar
RTT
Exclamation Water Pump
I found a water pump that fits a 1987 - 302 - Bronco/F150/Econoline . Why will this not fit a 1971 302 ? Does a 1971 f100 water pump have a backing plate ? I am hoping I can use my 1971 backing plate and 1971 gasket to use the 1987 waterpump ??? Or is the spacing/clearence from the radiator wrong ? Any way why will the 1987 not fit ?????????
Old Apr 1, 2022 | 10:52 AM
f31951truck's Avatar
f31951truck
Later model water pumps are set up for serpentine belts and also reverse flow impellers. I assume you have a v belt set up if stock. It would be wise to get the correct pump. Good luck.
Old Apr 1, 2022 | 11:05 AM
RTT's Avatar
RTT
Yes , I am finding that out .......thank-you............I did not realize serpintine started that soon.87...........I ask because I am constantly finding good parts at a bargain & try to find out if they will work on my truck.............thank-you for the help, I did need a quick answer & u DELIVERED
rcfreed
May 16, 2015 10:47 PM
streetrod00
Apr 9, 2012 08:59 AM
screwloose2
Feb 13, 2006 01:53 PM
screwloose2
Feb 12, 2006 07:30 PM
