got some issues
Old Mar 31, 2022 | 02:31 AM
wolfei's Avatar
wolfei
got some issues
i currently have a 1994 f150 4x4 5.0 v8. the transmission temperature sensor is spitting a code. i have the new sensor and was wondering where the old sensor is located and how much of a hassle is it to get to.
Old Mar 31, 2022 | 06:05 AM
rla2005's Avatar
rla2005
Before you tear into the transmission solenoid pack what was the code by number?
Before running the Key On Engine Off (KOEO) tests and Stored Code display did you warm up the engine and transmission? If not that Transmission Oil Temperature (TOT) code is most likely false.
A 1994 model year F150 w/5L engine could have one of two electronic controlled transmissions. The E4OD or 4R70W. Which do you have? Check the Transmission code listed on the driver side b-pillar sticker. Trans code E is an E4OD. Trans code U is a 4R70W. For the record there was a third option out there in 1994 for transmissions, the mechanical AOD. Since you are getting a TOT related code it does not apply for your scenario.
PhillipTyler
2015 - 2020 F150
Mar 16, 2021 06:35 AM
crew1
2015 - 2020 F150
Jun 10, 2018 08:39 AM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
geoaigel
1983 - 2012 Ranger & B-Series
Jan 10, 2005 10:50 AM
